Ford 1100 Compact
/ Ford 1100 Compact #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have a 1980 Ford 1100 diesel 2wd compact tractor. I started it up the other day to move and left it to warm up. When I came back to it it was leaking engine oil from the front of motor down onto front axle and dripped to ground. I haven't dug into it yet but was hoping someone here would point to what might be leaking.
/ Ford 1100 Compact #2
I guess anything near the front of the engine could be leaking. Clean it up the best you can, start the engine and try to see where the oil comes from. It may be coming from the front seal on the crankshaft or near the front of the oil pan. A light dusting of talcum powder may help you track it.
/ Ford 1100 Compact
Do you know anywhere to download a tech manual for the Shibaura LEK752C 2-cyl diesel?
/ Ford 1100 Compact #4
I have seen several on eBay.
/ Ford 1100 Compact
It appears the oil was coming out the overflow tube from the timing cover plate on the upper left side.
Pioneer PT Water Pump (A64911)
Pioneer PT Water...
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
2016 Ford Escape SE SUV (A66738)
2016 Ford Escape...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
John Deere 6400 (A64911)
John Deere 6400...
2015 KEYSTONE BULLET CAMPER (A67714)
2015 KEYSTONE...
