For those with block heaters
   / For those with block heaters #121
JRHO2 info
If your John Deere 410J doesn't have glow plugs, it might be because diesel engines use a process called compression ignition to ignite fuel instead. In compression ignition, fuel is injected into the combustion chamber while the air is being compressed.
willy
I can hardly believe that this was posted on these forums.
Perhaps I have missed something in this thread.
   / For those with block heaters #122
CalG - for some this site could be a major learning process. Hopefully.
   / For those with block heaters #123
1 hours always worked for me for the Case/IH that hates anything below 35F.
   / For those with block heaters #124
It may have been mentioned somewhere earlier. We don't live in a too cold climate. My TC45 has started no matter what temps it's in and I let it warm up much longer. Am I harming it in cold weather in this way?? Know nothing about them.
   / For those with block heaters #125
JRHO2 info
willy
The design of the diesel engine is compression ignition. The fuel ignites from heat produced from compressing the air to high pressure. The cold combustion chamber may not allow the fuel/air to get hot enough to combust. A cold engine will benefit this process if the combustion chamber is heated (glow plugs) or the incoming air charge is heated by an element. Sometimes, hot air from a hair dryer directed into the intake might help to get it started. A block heater getting the engine a bit warmer may help too. A warm engine will normally spin faster when cranking which helps too.
   / For those with block heaters #126
It's really surprising how just a little warmed air into the intake will fire off a stubborn engine, gas or diesel. I have a Kawasaki V Twin on my walk behind mower that gets real testy at 40-50 degrees F, and a few minutes worth a fan heater in front of the intake gets it going with 2 pulls.
   / For those with block heaters #127
… and cold hydro oil only adds to the trouble, for any machine with a direct-drive hydro pump. Especially zero turns, as they’re usually spec’d for hydro oil based on an assumption of warm weather operation. My Deere 757 ZTrak is spec’d to run 15W-40 in the hydro pump, and it is a bear to start in a cold shed after Christmas, when I cycle thru the annual maintenance on all my OPE.
I often end up firing up a jet heater in the shed, to warm it up for 30 minutes before that cold start.
I run ATF in my log splitter, which starts much easier in cold than any single-weight hydro oil. But with a big 20 GPM pump, it’s still not an easy pull, when it gets cold. I actually ended up installing electric start on it.
   / For those with block heaters #129
There is an outlet on the outside. My 2 questions are:
How long do you leave the heater running before you start it?
How well do the digital or mechanical timers work when they get really cold?
I’m in NE British Columbia. Can get bitterly cold here. I use a mechanical timer that plugs into a regular wall outlet. Don’t use a GFCI type outlet, they nuisance trip frequently. When the vehicles haven’t been plugged in I have found that 2 hours is sufficient for the block heater to do its job in temps down to -40. At that temperature you should just stay inside by the wood stove anyway.
   / For those with block heaters #130
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
260145 (A56859)
260145 (A56859)
2016 Ram 4500 Crew Cab Landscape Dump Truck (A56858)
2016 Ram 4500 Crew...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 132,994 Plate: Body Type... (A56859)
Year: 2014 Make...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2015 Jeep Cherokee 4X4 SUV (A56859)
2015 Jeep Cherokee...
