For those with block heaters
   / For those with block heaters #101
A very cheap way to hear the oil in your tractor use a 250
watt heat lamp attached it to a board slide under tractor
IMHO in 20 minutes the oil should be up to operating temp
willy
   / For those with block heaters #102
You might want something a little closer to the engine in places where it actually gets cold, but the old drop light under the hood trick has been used since well before my time. Maybe a blanket or tarp over the hood too if it's really cold.
Just make sure you use an incandescent bulb in it...an LED bulb ain't gonna cut it! :LOL:
   / For those with block heaters #103
willy
It also helps if you drape an old blanket or recycle an old kids sleeping bag over your tractor. Even a tarp can help. It can make a big difference if the tractor is outside in even a light breeze, but it also helps contain the heat when it is in a garage or barn.
Back when incandescent bulbs were still a big thing, we used to slide a couple of mechanic's "trouble lights" in the cowling of our plane, one on each side of the engine, and throw a blanket over the nose of the plane for a preheat on cold days. (Piston aircraft engines with their dissimilar metals in the piston and the cylinder really benefit from preheating in colder weather.) We've since upgraded to a commercial preheat system that does a faster and more even job of warming the engine and oil sump.
   / For those with block heaters #104
The light bulb warming an intake manifold and carb or injection pump makes a considerable difference in starting ability also.
   / For those with block heaters #105
I've also seen a hair dryer used to warm up the intake. They work really well for thawing out frozen stock waterers too. You guys down south don't get to fight with those in -30 weather either.
   / For those with block heaters #106
I actually bought a cordless heat gun for winter heat for locks or doors and such. Works very well as long as I remember to take it back in the house after using it, and not leaving it in the cab that the door latches like to freeze on. Nothing like trying to open the cab door and the latch not moving and knowing that I left the heat gun in the cab the previous day or so.
   / For those with block heaters #107
Only did the match/lighter heat the key once and it worked.
At Tahoe with my grandmother and the key would not go into the lock on her71 Skylark.
I remember reading about the key trick and she thought I was very smart for a 12 year old.
   / For those with block heaters #108
Be careful using heat lamps as there have been many a barns burned down using them.
   / For those with block heaters #109
Have to strongly disagree with the blowing up batteries. The battery blanket will make the battery warm to the touch. The fleet of police cars I worked on as a tech for the RCMP here all had them for the detachment cars around the province. In the fifteen years I was there, never had a blown up battery. Lost a few due to bad extension cords. Car warmers draw lots along with the block heater. The 35 watts the blanket draws wasn't the cause there either. I could imagine someone using a heat gun or a torch to try to heat a battery while charging having a very bad day. The hydrogen produced needs an ignition source.
   / For those with block heaters #110
Im not a fan of battery heaters. Ive seen too many exploded batteries from those overheating and boiling off electrolyte = hydrogen gas = boom.
The good battery warmers are either to low powered to get hot enough to boil off electrolyte or they are controlled by a thermostat. The thermostat ones I've seen generally shut off at about 65˚F.
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
Evercraft 3-1/2 Ton Floor Jack, 12-Ton Bottle Jack (A59076)
Evercraft 3-1/2...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A56435)
2003 International...
LOT OF I-BEAM (A58374)
