FOPS
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Some of you know what this, and some don't. Some machines have ROPS, but most PT's have ROPS, and FOPS . It is simply Falling Object Protection System. A lot of tractors have ROPS, but not FOPS. Solid FOPS are better. Some Skidsteers, have a thick wire cage overhead, but sharp limbs can still come through the grid and stick you in the head. I like that 1/4 in steel over my head, even if I do bump my head on it every now and then. Anyway, now you know.
Barryh said:
Kinda hurts doesn't it. :D
I still whack my head on it periodically -- doesn't hurt though. I padded the edges with self adhesive pipe insulation from Home Despot. It only has to be replaced when I rip it off against something that isn't hitting my face.
I like the ringing noise when a branch falls on the canopy --particularly when I think of the squishing noise that it would make if the FOPS weren't there. :eek:
It also makes a pretty good platform to stand on when you have to reach something up high.
Never used it for that.... good idea. I'll bet I could almost reach some of my gutters around back. Of course I have a home made roof over mine so thats out for now. ;)
I do too... luckly I have a really hard head. :rolleyes:
Charlie_Iliff said:
I like the ringing noise when a branch falls on the canopy...
I like the ringing noise it makes between my ears when I bonk my head on it. I listen to it as I slowly make my way to the ground before the dark tunnel closes up in my vision. :p
MR...dark tunnels are one thing as long as you don't see a bright light coming toward you!! I don't currently have ROPS on my 422 but when I finally get into my woodland project a year or two from now you can be certain it will be installed!
My wife made me get a ROPS when i got the 422..sure am glad. I havent rolled but is sure does provide alot of protection in the woods. ;)
It's a great thing to have. I also have a home made cab on mine. It looks a little weird, but it has kept me from getting hit in the face a couple of times in the woods when moving large dead tree limbs.
The heavy grade lexan front window has taken a real beating on several occasions where the limb slipped off of the bucket or forks and fell back in my direction. I have a very small crack at the bottom where it was hit, nothing bad it has not gotten any larger.;)
Barry, do you take your cab off in the summer? A cab would sure be nice in the winter but without a/c seems like it would get pretty stuffy in there when it's hot out. Of course, it would be nice to keep the Hornets out while field mowing too. I hate running over those nests.
I thought I would be taking it off when the heat got really bad, but I just ended up taking the side windows out, and my floor boards also come out.
It's not bad at all. As a matter of fact, I made the extended over lapping roof to keep the rain / snow off the windows. I found it also works pretty well as a sun shade. I even bought an electric fan for inside, but I haven’t needed to hook it up.
Don't think I would want to run over a nest of bees, and have them trapped inside with me that might hurt.
I did run over a nest with the riding mower a few years back. When I got stung I drove it back, and put the spinning deck over the nest intrance. I then jumped off and let it run full throttle for about ten minutes. Went back later that night poored gasoline into the hole along with powdered bug killer :eek: :)
If you Lived as close to the Hanford Nuclear Reservation as we do here, you coulda got some plutonium oxide to dump on them too.:D
My wife is from Kenewick. We now live in Woodland. Trying to get upwind of a bad situation, although her dad used to work at the reservation...
And then, in a terrible twist of fate, a race of super bees ruled the world for the next thousand years. :eek:
You beat me too it.;)
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2" X 2" DIAMOND BAR W/ SHANKS (A63291)
2" X 2" DIAMOND...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
iDrive TDS-2010H...
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
