foot controler
   / foot controler
I think I at have a bad switch because I bought 2 footcontrols I wired the other one up tonite and it works but when I wired up the one Ivebeen trying to get to work the sae way it still does not work!!! way to test switch??
   / foot controler #12
Use a meter to test from (C) common to the (NC) normally closed. the meter should pass power thru just like it has the two leads together. PUSH switch the signal shod show OPEN. Move lead from (NC) to (NO) and test again, the meter should read OPEN when switch is off and CLOSED (just like leads together) when pushed.
Check to make sure that you have the drill press switch turned ON when trying the foot switch.
Mark
   / foot controler
tested the switch it is bad have new one on the way thanks for the help
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2022 Iron Craft 10' 3pt. Rotary Mower (A50774)
2022 Iron Craft...
