food plots
   / food plots #1
2350
thawville
koyote
roto tiller or disc harrow for food plots
   / food plots #2
Welcome to TBN.
That's not a lot of info to go on, but I think the answer would be either. There are a lot of guys who use what they have and make do. Food plot seeds tend to be fairly forgiving so in a lot of cases they don't need a nice fluffed dirt bed like a tiller would give you, and do just fine with the end product of disks.
If you do a search for "food plot" on here, there may be some additional ideas you can read about.
   / food plots #3
:welcome: to TBN
Message posted with TractorByNet v1.6.2 for iPad
   / food plots #4
:welcome:
   / food plots #7
Welcome If the ground is clear both would work but if there are stumps ect. I would vote for the disc.
   / food plots #8
What type of seed? For brassicas and soybeans you need a deeper seed bed. Brassicas like turnips need deeper soil to grow they don't need to be panted deep. Soybeans need to be planted about 1/2" deep or so. Rye and forage oats don't need the depth for planting or growth.
With all of that, the better the seed bed the better chance for germination. Personally, I prefer th rotary tiller after spraying the area with a herbicide. That way I can plant whatever I want and be sure to have a good seed bed.
   / food plots #9
It really all depends on what you want to do. If you're looking to go deep and really break up any compaction in the soil, a plow and disc will go much deeper than a rotary tiller. The rotary tiller will give you more "fluff" with just a single pass than a plow or disc will though. Each has pros and cons. I currently have a single moldboard plow and 6' disc and have had really good luck. Using the disc and being creative with the top link, you can even make some raised rows etc.
   / food plots #10
2350- We really need some more info. Where are you located? I assume you are wanting to plant a food plot this spring? No matter where you live you should get a soil sample the very first thing- otherwise you will be wasting your time, please read this last sentence again because it is that important! I am in my 10th year of food plots and I have learned more than a few things along the way. Clover is the least work involved and it still requires a soil sample to get it to grow.
Oldstuff
   / food plots #12
+1 on the soil test.
   / food plots #13
I did not have a disc or a tiller and last year sprayed and killed about 2 acres with round up knock off. I mowed it down low with a shredder blade. I then used my box blade and dropped the tines down as far as I could and tore heck out of it. I let is set a couple of weeks and went over it several times with the box blade/tines low. I drug heavy log chain behind the box blade in a u shape to help break up clods. I did not need to lime as the ph was good. I put about 300 pounds of 12-12-12 on it. I planted brassicas, clover and alfalfa and wow did I get a nice crop of turnips, clover and alfalfa! Deer sure liked it!
   / food plots #14
I resemble the above remark. I have tried almost every option. Settle a few years back on a chisel plow and disc. Works great, but recently I decided to bite the bullet and get a five foot King Kutter Tiller from Tractor Supply. Unbelievable what it does on one pass on old pasture land with thick fescue and/or bermuda. I am sold on it, but my soil is sandy loam old pasture, so not much problem with roots, stumps, big rocks.
I have a few food plots back in the woods. There I use the disc only, as the tiller would not deal so well with solid roots from big oaks, hickory and pines.
   / food plots #15
I say "use whatever you got". I had one plot was mid-jungle, used my backhoe to widen a path in and dug up about 1/3 to 1/4 acre, de-stoned and then disced & chain harrowed. Works very well. Took awhile but when you do what you love, doesn't seem like so much work.
   / food plots #17
I've live on my farm for about 45 years now. I've got one food plot in the back it's about 5 ac . I've farmed it with every piece of equipment I've got . Jubilee case 830 and even my IH 1086 and a big offset. Best crop I had back there was a summer plot . I put it in with my 830 I just plowed it with a finishing tandem So I did not plow to deep . But then I used my whirly Bird seeder ... I mixed it all together . I had some of that Lab Lab . Soybeans. Corn. Black Eyed Peas. Milo. and a 50lb bag of spring mix from Bass Pro or some place like that. It rained that year ..
.. When I drove up to that patch deer stood up an ran out for 15 minutes each time . It stayed ahead of them all summer and was about 4 ft tall .. Wife & I picked a log of BlackEyed Peas out of it.
.....This winter it's dry and you can just barely see the Oats I have planted there & no deer. This year I rigged up an old grain drill that I'd not used in about 10 years. I was showing the grand Kids what can be done. I spend about $150.00 a year on my food plot avg.
   / food plots #18
My disk has not touched the tractor since I got the tiller a few years ago.
   / food plots #19
Where I am in North Florida it is important to roll in your plot seed. We have two month Spring and two month Fall dry periods and rolling improves germination if weather does not cooperate.
For years I pulled a Brinley water-filled plastic lawn roller behind my Kubota B3300SU. Took off the lawn roller rubber grips and inserted one length of 3/4" all-thread in each end of handle, inserted all-thread in 3-Pt. "eyes" then secured with washer and nut on each side. Roller filled in space between tractor tires giving total roll width, with tires, of 58".
Roller available from Home Depot/Lowes, yard sales etc. Meant to be pulled/push by "hand" so frame is not strong enough to withstand REVERSE on tractor. Forward works fine. I carried roller to the food plot in bucket, then nutted into "eyes".
Recently purchased a 60" Cultipacker from Everything Attachments. I am not sure germination will improve but intend Cultipacker will cure persistant erosion sites by rolling crimp pattern across slopes after seeding.
Tractor is a Kubota B3300SU / 33-hp / 1,900 pounds.​
   / food plots #20
I plowed up one food bed and then ran the disc over it. The second food plot I just ran the disc over grass. It was clay soil and the disc took a lot of time. So I think roto til. Since I don't have one, I think next time I will use herbicide and then disc. Just my experience. BTW :welcome:
2015 Vermeer D9X13III Directional Boring Machine (A59228)
2015 Vermeer...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
