Tires foed 1710 turf tire inflation
   / foed 1710 turf tire inflation #1
SuperChief
Ford 1710, 8N, 600
Not used to seeing tire pressures being lower than my car. need tire pressures f/r for 1710 turf. have searched threads to no avail. thanx
   / foed 1710 turf tire inflation #2
18-20 psi for the fronts. Rear inflation is based on he weight the axle carries which varies a lot. You should see some sidewall deflection at the contact point. Could vary from 8-24 psi depending. My advise always has been if it looks soft it probably is. There is no one fits all answer.
   / foed 1710 turf tire inflation #3
^^agree^^ I would have about 10-15 in the rear though.
Thanks to all, I did get an operators manual, but it only addresses the weight to inflation but gives no inflation pound info. I will only be doing low weed bush cutting and driveway maintenance with a scrape blade, so the recommended inflation is greatly appreciated,
   / foed 1710 turf tire inflation #5
Just like ATV tires, tractor turfs are more susceptible to punctures when they are over inflated.
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2019 Chevrolet Cruze Sedan (A50324)
2019 Chevrolet...
