Tires foed 1710 turf tire inflation
   / foed 1710 turf tire inflation #1
SuperChief
Ford 1710, 8N, 600
Not used to seeing tire pressures being lower than my car. need tire pressures f/r for 1710 turf. have searched threads to no avail. thanx
   / foed 1710 turf tire inflation #2
18-20 psi for the fronts. Rear inflation is based on he weight the axle carries which varies a lot. You should see some sidewall deflection at the contact point. Could vary from 8-24 psi depending. My advise always has been if it looks soft it probably is. There is no one fits all answer.
   / foed 1710 turf tire inflation #3
^^agree^^ I would have about 10-15 in the rear though.
Thanks to all, I did get an operators manual, but it only addresses the weight to inflation but gives no inflation pound info. I will only be doing low weed bush cutting and driveway maintenance with a scrape blade, so the recommended inflation is greatly appreciated,
   / foed 1710 turf tire inflation #5
Just like ATV tires, tractor turfs are more susceptible to punctures when they are over inflated.
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
CFG Industrial H15R (A50121)
CFG Industrial...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
