Foamy yellow 80-90 Gear lube in axel?
   / Foamy yellow 80-90 Gear lube in axel? #1
iplumb
Mason MI.
B2920
Just changed the engine oil in my B2920 when I checked my front axel after running it the gear lube looked foamy? Is this normal? I only have about 20 hours on the lube but kits been over a year since I changed it. I have A total of 77 hrs on this 09 thanks.
   / Foamy yellow 80-90 Gear lube in axel? #2
Did you use a anti foam gear oil?
Chris
Chris
I used Kubota 80/90
   / Foamy yellow 80-90 Gear lube in axel? #4
Did you get into water?
   / Foamy yellow 80-90 Gear lube in axel? #5
My used meteor snowblower had a weird yellow gear lube I had never seen before. I called MK Martin (who makes Meteor), they said that's what they used from the factory. I had never seen yellow gear lube, but it;s out there!
   / Foamy yellow 80-90 Gear lube in axel? #6
be carefull.. water emulsion into gear oil will turn it into a milkshake. at that point it can froth and foam even if it was a foam rejecting oil.
No, it's never really even been in the rain. I think some of the yellow is the dip stick. I was more worried about the foamy appearance. But I think it was just because I had used the tractor.
   / Foamy yellow 80-90 Gear lube in axel? #8
check it again after setting.
if in question drain an ounce or two into a glass jar
Good idea! Thanks
   / Foamy yellow 80-90 Gear lube in axel? #10
post back what ya find
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
