Foamy yellow 80-90 Gear lube in axel?
   / Foamy yellow 80-90 Gear lube in axel? #1
iplumb
Mason MI.
B2920
Just changed the engine oil in my B2920 when I checked my front axel after running it the gear lube looked foamy? Is this normal? I only have about 20 hours on the lube but kits been over a year since I changed it. I have A total of 77 hrs on this 09 thanks.
   / Foamy yellow 80-90 Gear lube in axel? #2
Did you use a anti foam gear oil?
Chris
Chris
I used Kubota 80/90
   / Foamy yellow 80-90 Gear lube in axel? #4
Did you get into water?
   / Foamy yellow 80-90 Gear lube in axel? #5
My used meteor snowblower had a weird yellow gear lube I had never seen before. I called MK Martin (who makes Meteor), they said that's what they used from the factory. I had never seen yellow gear lube, but it;s out there!
   / Foamy yellow 80-90 Gear lube in axel? #6
be carefull.. water emulsion into gear oil will turn it into a milkshake. at that point it can froth and foam even if it was a foam rejecting oil.
No, it's never really even been in the rain. I think some of the yellow is the dip stick. I was more worried about the foamy appearance. But I think it was just because I had used the tractor.
   / Foamy yellow 80-90 Gear lube in axel? #8
check it again after setting.
if in question drain an ounce or two into a glass jar
Good idea! Thanks
   / Foamy yellow 80-90 Gear lube in axel? #10
post back what ya find
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
