foam filled tires
/ foam filled tires #1
khamill2000
central Kansas
Mahindra 2815 HST
Called up a local place today to get a price on filling my tires with foam. I was thinking about 5-600$. The quote I got was $1682. That fills 2 27x15 ($157@) and 2 15x19.5 (684@). Even the quote for my mower was terrible ($200). Anybody had this done recently and does this sound like a current price?
/ foam filled tires #2
ARRRGGGHHHHH! CRASH..............
That was the sound of me clutching my chest and falling out of my chair.
A local tire shop here used to charge about $15.00 for finish mower tires (3-4 yrs ago). Regardless of what they might charge now, your quote sounds outrageous. Just my 2 cents.
/ foam filled tires
The little 4.10x3.50-5 tires on the mower were 15 each
/ foam filled tires #4
Just had my BX tires filled. 310 pounds at $1.25 per pound. In on Friday late afternoon, picked up on Monday first thing in the morning. Cheap investment for the difference in the machine. 2 ea. 26x12-12 and 2ea. 18x8.5-10
The place had a chart that showed how many pounds a tire held and that's what he charged.
/ foam filled tires #6
Do you have a link, or contact info?
/ foam filled tires #7
Are foam filled tires hard on the drive train and transmission?
/ foam filled tires #8
Les Schwab charged me $2.00 a lb for foam fill on the front tires for my Kubota those are 9.5x16 I think. 168 lbs in each tire times two :eek:
/ foam filled tires #9
WOW!!! I only paid 50 bucks to get to front tires done on a JD 2350
/ foam filled tires #12
What ever the price would be
The first time u have a flat
U would say Darn wish i had done that
I had ONE front ..... Flat and it was the Last one
DougM
/ foam filled tires #13
I paid $175 each to have the rear tires on my BX23 foam filled.
Seemed like every 20 or so hours I was getting a flat.
I've noticed the added weight really help on my hillside property with stability... also the tractor tends to stay put when using the Backhoe.
/ foam filled tires #14
You have to shop/compare price per pound or price per gallon of foam; Otherwise, you're trying to compare the price of eggs to watermelons. Used tires will take 10-15% more foam than a new tire. Some places won't even fill a used tire while some may require you buy a tube and charge you to install the tube before filling with foam. There's too many variables to compare prices from a 100 different tractor owners.
Most tractor manuals have the added weight of any given size tire that's filled with water. The chart usually has the tire sizes for your tractor. It normally gives the gallons as well. Since the foam and water are pretty close to the same weight per gallon, use the charts to determine if they're bending you over a barrel or giving you a square deal.
Ask them to price your tire size(s) then ask how many pounds of fill that price is based on. Some simple math will tell you the price per pound and whether it's close to the pounds of water held in your tires. (All charts are based on new tires.)
/ foam filled tires #15
Thinking about foam tires.Any differents i ride. Have foam filled on fork lift
bumpy on hard surface.framer
/ foam filled tires #16
I don't notice any difference with my BX when I'm working my property. It's hillside so I'm in low range 95% of the time.
/ foam filled tires #17
Just had all 4 on the new b26 filled and it was a little more than $1,100, it added about 800lbs. Also have foam filled on the front of a M5400 and have not had an issue since just wish I could afford the rears(about $2500). You should make sure the shop that does it lets the tires cure before you pick them up or you will have issues.
/ foam filled tires #18
I see a couple of posters here mention added hillside stability. I live on a pretty hilly place, and tend to spend most of my time going up and down slows as opposed to acceoss them due to fear! When you say foam filling tires added stability, can you qualify this and provide some detail? I've got a Kubota B7800
/ foam filled tires #19
Foam tires add weight and the weight is close to the ground providing a lower center of gravity.
My BX is not used for mowing, so the extra weight is only a plus for me.
I had my rears filled because I had lost too many weekends of seat time due to flats...
The stability was just an added bonus.
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A65053)
2014 VOLVO A25G...
Front Tank Bracket (A64126)
Front Tank Bracket...
Teakwood Rocking Horse (A65583)
Teakwood Rocking...
