Fluid level and capacity
   / Fluid level and capacity #1
lagomasino
Cherry Grove, WV
Kubota B2620
I did the 50 hr service on my B2620 last weekend. I replaced all filters and changed the hydraulic fluids. According to the manual, the front axle and that transmission holds about 5 gals of UDT fluid. When I took all the fluids out I didn't produce 5 gals. And when I put the new fluid back in, I had about 1/2 gal left. The level on both the transmission and the front axle are above the max level - by about 1/4 inch. The questions are:
1. Will it hurt to leave the fluids on the transmission and front axle above max?
2. Why didn't I produce 5 gal when I drained the fluids?
I empty all the drain plugs until it was just dripping slowly.
The engine oil changed was OK.
Thanks for any input
   / Fluid level and capacity #2
I have never found anything that holds the exact amount of fluid specified. My Bx 2200 held about a pint more engine oil than specified before it read full on the dipstick, and a friend's held even more.
I don't think a quarter inch is anything to worry about.
Will
   / Fluid level and capacity #3
You're not alone. I had the same concern on my 300 hour for BX2350. Front axle is supposed to take 4.7 litres. It was filled too high and I still had .5 of a litre to go. Rather than worry about the overfill, I used an old turkey baster to suck out the amount it was over the fill line. I checked the dipstick the other day just to see if level was down and it was still fine.
   / Fluid level and capacity #4
x2.
You may also find the front axle level drops a little after some use. Apparently there are some tight squeezes before the oil gets into the bevel housings.
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
iDrive TDS-2010H...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2006 CATERPILLAR 242B SKID STEER (A60429)
2006 CATERPILLAR...
