Fluid Film rust perventative ??
   / Fluid Film rust perventative ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Has anyone used this product called Eureka Fluid film rust and corrosion preventative?Thanks for any information,coobie
   / Fluid Film rust perventative ?? #2
Fantastic stuff. I just sprayed the underside of my car trailer last week since it was rusting. I've also sprayed the underside of my truck with it...messy but a very effective rust preventative. I'm on my third gallon since discovering the stuff about 5 years ago..
Thanks for the info.I just ordered 2 gal.this evening.coobie
   / Fluid Film rust perventative ?? #4
How long does it last? Does it attract dust?
larry
larry
There is alot of good info.on there website.coobie
   / Fluid Film rust perventative ?? #6
I've only used it on some 3 point hitch attachment pins on a single bottom plow. The plow gets used in the spring, then sits around outside waiting for a year. Sometimes, I touch-up the pins with another squirt or two, just because it seems like I should. ;) No rust. Amazing stuff!!
   / Fluid Film rust perventative ?? #7
I'm using Fluid Film as well. The dealer gave me a free can a few years ago and I have been buying it ever since. Bought a gallon around Christmas. :D
Lanolin is the "active" ingredient. Its seems to last a long time and does not really collect dust. I use it all over the place, on shovels, box blade teeth, 3PH ball joints, PTO shaft, anything metal.
I globbed some about half way down the shovel. This stuff somehow spread UP. It holds up in the rain real well. I sprayed my box blade teeth which are leaning against a tree. It clean up the rust and there is not any new stuff on the teeth which have been sitting for a few months. The only problem I have is with the 1 gallon can is the stuff is very thick. I bought a pump up sprayer in the garden section which kinda works. Not wll but it works. It does not so much as spray as spew because the Fluid Film is so thick. But that is the fault of the sprayer not Fluid Film.
Its great stuff.
Later,
Dan
I bought 2 gal. of the fluid film last week and tried some on my tractor that had some corrision.This stuff is pretty neat,took the corrision off the bolts and left a nice film.I agree it is thick,I put mine on with a small paint brush.I am going to try a airless sprayer next to apply it to the brush hog and some other things.coobie
   / Fluid Film rust perventative ?? #9
Cobbie,
What kind of airless sprayer are you going to use?
I looked at some sprayers in the big box store and was not sure if they would work so I just used the garden sprayer as well as a rag.
Later,
Dan
   / Fluid Film rust perventative ?? #10
I use one of those air siphon sprayers like they sell for engine cleaning, works very well. I do sometimes thin the Fluid Film with any solvent I happen to have on hand like mineral spirits, MEK, or paint thinner. I sometimes even cut it with bulk WD40 I also buy by the gallon;)
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
Ford Tractor (A50120)
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
