Fluid choices for CH20HST?
/ Fluid choices for CH20HST? #1
chelydra
Ditch Witch
I'm going through a lot of hydraulic/transmission fluid due to a leaking valve. Until that gets sorted, I may need another 10 gallons or so - most of which will end up on the ground, alas.
Dealer uses Exxon Hydraul 560, which is hard to find around here (Eastern MA). Any recommendations for products available at Napa, Autozone or the like? Anything in particular to avoid?
Thanks!
/ Fluid choices for CH20HST? #2
What valve is leaking? I would not want to operate the machine if it is leaking that much...
It's one of the backhoe controls. Not visibly flowing, but loses a quart or so each time I run it - steady drip, then more on the garage floor when I park, even after letting down both buckets to relieve system pressure.
/ Fluid choices for CH20HST? #4
is it a Kioti backhoe? If so, mine was doing the same thing. What I found was the o-rings under the 90 degree elbows were leaking because the existing o-rongs were mashed down. So much so that it looked like they were the wrong ones. I used Gates o-rings part # G60248-0008 on all 12 fittings. Solved the problem for good. The o-ring at the bottom of the pic is a good example of how they looked
/ Fluid choices for CH20HST? #5
I purchased valvoline Universal Tractor Fluid UTF at Napa here in Washington in 5 gallon buckets. Seems to work just fine. It is made for hydraulic/transmission fluid shared applications.
10 gallons is a lot to waste. Too bad, but if you must run it then you should have the oil on hand to top up as needed.
/ Fluid choices for CH20HST? #6
yeah............I was slightly off topic.............adressing the leak. Universal Tractor Fluid of any brand I'm told. If one brand over another someone else will need to explain but the fluid is nothing exotic
Nothing off-topic about trying to help! The leak is around the left-right boom swing valve pin (if that's the correct word) on the KB2365 left-hand control. I tightened the three allen bolts down as far as I dared - not very far - which didn't seem to help at all. I hate to pay the dealer almost $100 to pick up and drop off the machine, and possibly pay for a repair as well. It's under warranty, but he says that tightening isn't covered. (If I break off the bolts, is that covered?) I'm really curious as to why this would have started right after I had them do the initial 50-hour service, and also why the hoe boom now screeches pretty loudly when I pull in from long extensions. They said that it might be due to different greasing, but I wonder...
Anyway, I wound up with Napa fluid at $30/5 gal. I hope not to run through all that too fast!
Thanks for all the good advice on- and off-list.
Narrow-band in Boston
/ Fluid choices for CH20HST? #8
yup.................I had about 10 hours on mine when it started leaking. How many hours on yours? How is a hyd not covered under warranty? That's a new one on me /forums/images/graemlins/confused.gif
/ Fluid choices for CH20HST? #9
Chelydra,
The problem you are have with your Kioti backhoe is a very well known problem and Kioti is well aware of that problem.
You can tighten those allen bolts as much as you want and will not do a thing.
The o-ring has already been blown out.
It will have to go back to the dealer, It is ALL covered under warranty.
/ Fluid choices for CH20HST? #10
Rick
Mine did something like that, only on this one it was a bad weld at the outter end of one of the swing cylinders. Kioti replaced the cylinder and all is well again. /forums/images/graemlins/smile.gif
Al
/ Fluid choices for CH20HST? #11
The shop manual for my CK30hst suggests that squelling hydralics can be caused by the wrong weight oil. Especially if noticed right after an oil change. As DrewL stated, the oil is not exotic but there are different weight oils. When you just look for a universal oil, the weight isn't always marked on the container. Also, different companies add there own blend of additives for corrosion, anti-foaming, etc. I'd try to use what the tractor calls for or if you have an oil distributor in the area, they usually can cross reference their brand of oils to another brand to match specifications.
/ Fluid choices for CH20HST? #12
Warren AW48 or AW68 are good, resonably priced fluids that work well in Kioti. Antifoaming agents are good to have as foaming fluids do not lubricate well. Just make sure that whatever fluid you buy has them. Making sure you keep the level between the marks on the stick can help avoid the squealing you're getting.
Swing boom O-rings are notoriously overtightened and usually need to be replaced. It's an easy job. Just turn the boom to the opposite side, remove the fitting, replace the O-ring making sure you don't tighten it too tight to begin with.
John
)</font>
Hmm... given that the dealer isn't being as helpful as I'd hoped, it might be nice to check in with Kioti/Daedong USA. Since their web site gives only e-mail and fax contact info, I sent an e-mail and got no response. Anyone here know if they're willing to be phoned? Otherwise, I'll just tangle it up with the dealer.
Thanks-
NBB
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
