fluid check
   / fluid check #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
What is the proper way to check trans fluid, lift up or down?? :(
   / fluid check #2
I check mine with the FEL & 3-point down. This is what my Op Manual recommends.
   / fluid check #3
If you mean hydraulic fluid, you want all cylinders retracted when you check it.
   / fluid check #4
Actually when you think about it - probably does not make much difference. It takes hydraulic oil & pressure to move any/all cylinders in either direction. There had better not be a time when any of your cylinders are devoid of hydraulic oil.
   / fluid check #5
except that you are thinking of dual acting cylinders with oil on either side.. Most internal lift cylinders are simply a cavity with a moving piston, and oil only on one side.
Still, in an 8n that holds 4.5-5g of oil.. the lift cyl capacity is about 12 ounces.. so it makes little difference on the internal cyl.
best way to check is to remove the bottom bolt from the round dipstick cover. fill oil till it dribbles from there. this keeps oil MOSTLY off the old axle seals and lubing your brake pads.. but still lets stuff that need lube get it.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2024 Deere 317G (A50123)
2024 Deere 317G...
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
2005 Dodge RAM 1500 (A50123)
2005 Dodge RAM...
