fluid check
   / fluid check #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
What is the proper way to check trans fluid, lift up or down?? :(
   / fluid check #2
I check mine with the FEL & 3-point down. This is what my Op Manual recommends.
   / fluid check #3
If you mean hydraulic fluid, you want all cylinders retracted when you check it.
   / fluid check #4
Actually when you think about it - probably does not make much difference. It takes hydraulic oil & pressure to move any/all cylinders in either direction. There had better not be a time when any of your cylinders are devoid of hydraulic oil.
   / fluid check #5
except that you are thinking of dual acting cylinders with oil on either side.. Most internal lift cylinders are simply a cavity with a moving piston, and oil only on one side.
Still, in an 8n that holds 4.5-5g of oil.. the lift cyl capacity is about 12 ounces.. so it makes little difference on the internal cyl.
best way to check is to remove the bottom bolt from the round dipstick cover. fill oil till it dribbles from there. this keeps oil MOSTLY off the old axle seals and lubing your brake pads.. but still lets stuff that need lube get it.
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
