Flow restrictors
/ Flow restrictors #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Decided to put a cylinder on my drum mower to lift the tip. Had a 2" diameter cylinder on a Ford 3910, ⅜" hoses. Thought about a fixed restrictor fitting but couldn't find much and what I did find was really pricy. I decided on a variable 2 way needle valve from All States Ag. Parts for like $27, had it in a couple of days. Just now forget the total turns, at least 3 full turns lock to lock, but wound up with it set 90* open (quarter turn) from fully closed. Really glad I didn't go for a fixed one as whatever I would have ordered would have been way too big.
/ Flow restrictors #3
I added an adjustable flow control to my Tilt-Tach. It moved too quick and too far without it.
That is it on the hose on the right side of the cylinder in the picture:
/ Flow restrictors #4
Adjustable flow control valve shown below.
/ Flow restrictors #5
I've got piloted check valves on my top and tilt cylinders to prevent leak down. No flow into the cylinder until 500 psi, and then a surge. Makes it hard to tweek the rear blade angle. Been thinking about adding a variable flow restrictor but before doing that, does anyone know if the pilot pressure can be adjusted down? 500 psi seems like a lot.
/ Flow restrictors #6
I think those valves were invented by a club-fisted Neanderthal who had no fine touch for hydraulic valve handles. :D
/ Flow restrictors #7
Some machines run the aux hydraulics with a electric over hyd switch that can be touchy. My grapple lid (single 2") was VERY fast and would slam open/shut so I'm using a fixed restrictor in a hose. It is run with a thumb operated toggle switch on the loader control.
/ Flow restrictors #8
I like these better in most cases, cost more yes, but most times I want to control speed in one direction and unrestricted in the other.
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
John Deere 4044M (A60462)
John Deere 4044M...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
John Deere 1025R (A64126)
John Deere 1025R...
IH International 1466 Tractor (A66285)
IH International...
