Flow control For Tractor Mounted Log Splitter.
   / Flow control For Tractor Mounted Log Splitter. #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
On a previous Ford tractor I have owned there was a physical notch on the rear hydraulics handle where the lever could be set at a full flow position where one could use the open and close lever on a remote log splitter to actuate the cylinder. My Boomer 50 does not work this way and I have no way to set the lever on the side of the seat full flow to use a log splitter. How does one get around this? If I use a bungie strap to hold the lever open at the tractor seat and then used the lever on the log splitter remotely would this hurt the tractor hydraulics?
Thanks.....
   / Flow control For Tractor Mounted Log Splitter. #2
No, as the fluid is still flowing back to tank in a series flow.
2016 Poulan Pro PP19A42 42in Riding Mower (A48082)
2016 Poulan Pro...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2014 Kenworth T400 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A48081)
2014 Kenworth T400...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2020 Kia Rio Sedan (A48082)
2020 Kia Rio Sedan...
2018 Toro Sand Pro 5040 Bunker Rake (A49346)
2018 Toro Sand Pro...
