Floor jack
/ Floor jack
Does the off road jack roll ok on gravel so it doesn't pull the jack away from the vehicle when you are raising it like the small solid wheel jacks tend to do?
With the bigger wheels tends to pull the jack under the lift. Ground condition and weight that could vary. The rear wheels don’t swivel but the pump handle locks to raise the front wheels to maneuver. Little different from other jacks.
/ Floor jack #55
Yours it’s to tall. Can’t get that under a car with a flat
I bumped this thread because I'm considering getting one for my nephew that will likely do some auto work outside.
He has 2 vehicles. A 1999 F350 4x4, and a newer Honda Insight.
A little extra height, as well as that jack extension might be handy for the F350. However, the Honda Insight is tight underneath.
3 Ton (6,000 lbs) should be enough for jacking 1 corner of the f350.
I've been reasonably happy with a Pittsburgh 3T aluminum jack.
However, I find myself frequently throwing a non-OSHA approved wooden block on it to lift.
So, the Badland jack may well be slightly better for the taller pickup, but not as good for the Honda.
The Pittsburgh 3T Aluminum jack is rated for 3 3/4" to 19 1/8".
The Badland jack is rated for jacking from 6 1/4" to 29 1/16" (I assume including the extension for the high measurement).
/ Floor jack #56
There are a few companies that sell similar jacks on Amazon. However, perhaps the biggest competitor to the Badlands is Pro Eagle.
3 Ton Big Wheel Off Road Jack "Kratos"
Definitely some similarities between the Badlands and the Pro Eagle. But, at twice the cost.
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2014 JCB 930 (A53317)
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
Caterpillar 308E2CR (A60462)
Caterpillar...
