Floor finish in the tractor garage
   / Floor finish in the tractor garage #1
JonKioti
Newfoundland, Canada
CK-20S HST
Hi all,
I've taken the time to build a semi-heated space for my tractor; I have a power trowel finished slab on grade. I'm hoping (probably in vain) for a clean space which is easy to clean up dirt, debris, etc.
Does anyone have a suggestion as to what to use? I'm looking toward an epoxy coating, but maybe someone has an idea of something else.
Thanks!
Jon
   / Floor finish in the tractor garage #2
I would just use a good sealer
   / Floor finish in the tractor garage #3
ditto
becareful how smooth you make it when trowelling, because when you add sealer or epoxy it maybe TOO smooth, and you might fall on your a-- when its wet. don't askhow I know.
(In jest) - we're not allowed to hunt the seals anymore, so it should be easy to find a good sealer. :)
A good concrete sealer in one option, for sure. It does make for a dark colour floor, but has less steps than the epoxy.
Joe, thanks for the tip. I will test with non-critical area first (the job will be done in sections).
Jon
   / Floor finish in the tractor garage #6
when we pored our basement we flooded it with an acrylic based sealer - did not change the color of the concrete, but water beads up plenty well.
   / Floor finish in the tractor garage #7
When talking to concrete finishers I have always asked for a broom finish, rough enough so I don't slip when it is wet, smooth enough so I don't tear my clothes when I crawl under a car. All the finishers I have hired have been able to do this.
I just leave it "as is". Dust sweeps up well, oil spills go away with absorbent, followed by clean absorbent and some paint thinner.
   / Floor finish in the tractor garage #8
I think the concrete has already been poured:rolleyes:
   / Floor finish in the tractor garage #9
"build a semi-heated space for my tractor"
What does "semi-heated" mean?
   / Floor finish in the tractor garage #10
Maybe a wood stove. Heated only semi-the-time when you're there to throw a few logs in. :)
Bucket (A55973)
Bucket (A55973)
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
Deere 335P (A53317)
Deere 335P (A53317)
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
