Floor finish in the tractor garage
   / Floor finish in the tractor garage #1
JonKioti
Newfoundland, Canada
CK-20S HST
Hi all,
I've taken the time to build a semi-heated space for my tractor; I have a power trowel finished slab on grade. I'm hoping (probably in vain) for a clean space which is easy to clean up dirt, debris, etc.
Does anyone have a suggestion as to what to use? I'm looking toward an epoxy coating, but maybe someone has an idea of something else.
Thanks!
Jon
   / Floor finish in the tractor garage #2
I would just use a good sealer
   / Floor finish in the tractor garage #3
ditto
becareful how smooth you make it when trowelling, because when you add sealer or epoxy it maybe TOO smooth, and you might fall on your a-- when its wet. don't askhow I know.
(In jest) - we're not allowed to hunt the seals anymore, so it should be easy to find a good sealer. :)
A good concrete sealer in one option, for sure. It does make for a dark colour floor, but has less steps than the epoxy.
Joe, thanks for the tip. I will test with non-critical area first (the job will be done in sections).
Jon
   / Floor finish in the tractor garage #6
when we pored our basement we flooded it with an acrylic based sealer - did not change the color of the concrete, but water beads up plenty well.
   / Floor finish in the tractor garage #7
When talking to concrete finishers I have always asked for a broom finish, rough enough so I don't slip when it is wet, smooth enough so I don't tear my clothes when I crawl under a car. All the finishers I have hired have been able to do this.
I just leave it "as is". Dust sweeps up well, oil spills go away with absorbent, followed by clean absorbent and some paint thinner.
   / Floor finish in the tractor garage #8
I think the concrete has already been poured:rolleyes:
   / Floor finish in the tractor garage #9
"build a semi-heated space for my tractor"
What does "semi-heated" mean?
   / Floor finish in the tractor garage #10
Maybe a wood stove. Heated only semi-the-time when you're there to throw a few logs in. :)
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
18-Drawer Stationary Tool Box w/Contents, 67" W x 24" D x 80" H (A59076)
18-Drawer...
17101 (A55851)
17101 (A55851)
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
