FLOAT???
/ FLOAT??? #1
albert
middle Tn
Toolcat D
Could someone please explain to me how, when, and why to use the boom float on a 5600 D.
/ FLOAT??? #2
Not sure about your model but I'll take a stab at it...
"Normally" float is used to back drag ruts (or any uneven ground) to kind of flatted out a surface. It will also break up clods of dirt. Some people also use it for blowing snow off pavement... (I don't know about that).
So if you push your FEL joystick forward, there will be resistance before it locks into the Float Detent position (kind of a locking or latching feeling). Again, this is on tractors, not sure about a toolcat!!! BEFORE even starting the engine, you should be able to move your FEL joystick and feel where it locks into place.
/ FLOAT??? #3
"Float" releases the hydraulic pressure in the front lift arms, so that the downward force of the attachment is effectively just the weight of the attachment itself. If you are dragging a bucket in reverse, float may be what you want. If you float a bucket and move forward, the bucket's front edge will dig in on soft surfaces. The effectiveness/benefit of using float with an attachment is a combination of the downward force of the attachment (how heavy it is), the hardness of the surface (dirt, gravel, pavement), and whether the front edge of the attachment will dig into the surface (many attachments with skids are designed to be floated while moving forward).
Since floating the attachment means that the weight of the attachment is resting on the ground/pavement and not on the front wheels, this can cause the front wheels to loose traction. This is true when floating a snowblade or snow blower, especially when going uphill. If you need more traction/steering control, lift the blade/blower so that the weight of the front attachment is now on the front wheels. On the Toolcat, be sure to place the attachment on the ground/road before going into float mode, since this quickly drops the attachment.
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
HYSTER H30XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H30XL...
2005 Ford F-650 2,000 Gallon Water Truck (A61568)
2005 Ford F-650...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2016 CATERPILLAR 305E2 CR EXCAVATOR (A62129)
2016 CATERPILLAR...
