Float Valve
   / Float Valve #1
BratFarm
Kubota, Zetor, Ferguson, and John Deere
My Zetor is supposed to have a float valve (described in the owner's manual and verified by the previous owner). The lever does not detent when pushed forward. Do I need to adjust cables or just clean up the connections?
   / Float Valve #2
Under the bottom of the valve, there should be some caps/covers, covering the ends of the spool. Carefully remove them , inspect, clean, and lube. There is probably rust in and around the groove the balls set.
There are balls and springs under there, don't lose them.
   / Float Valve
Thank you sir, I will give that a shot when I build up enough courage to lie in the cold snow under the beast. Wish I had a taller barn door. Appreciate the warning about the jack in the box. You must have seen me work before.
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
2004 Workhorse Custom Chassis W22 Incomplete Vehicle, VIN # 5B4MP67G143386098 (A53424)
2004 Workhorse...
