Float feature- how do I know?
   / Float feature- how do I know? #1
WBWI
SE Wisconsin
Kubota L3130
I bought my L3130 used a few weeks ago from a private party. It has a factory FEL and aftermarket rear mounted snow blower. I've seen the term "float" several times in relation to the hydraulics and loader operation. The Kuboa info I've seen says the float feature is optional. How do I know if my tractor has that capability?
   / Float feature- how do I know? #2
On my L3400 the FEL float feature is accessed by throwing the FEL stick all the way up, as if you were trying to lower the FEL all the way. There is a perceptable 'thunk' as the stick drops into a detent. But you have to really throw the control stick all the way up, not just gently move it up.
If your tractor has the float feature then the FEL will drop to the ground without lifting the front end of the tractor up. This is quite different than if you were to simply put the FEL on the ground and keep pushing it down. When floating there is no hydraulic force being applied to the FEL.
   / Float feature- how do I know? #3
You don't need the tractor running or a hydraulic implement attached. Simply put, a "float" valve is technically a 4 way valve, meaning it has 4 distinct positions.
1. Normal, spring loaded, static position is centered with no hydraulic action.
2. Moving the handle one direction, the handle will move against a spring until it reaches the end of it's stroke where it would cause a cylinder to extend or retract. This position is lost when you remove your hand from the handle at which time it will return to the original static position number 1.
3. Moving the handle the other direction it will come against a spring until it reaches resistance and stops moving where it would cause a cylinder to extend or retract. This position is lost when you remove your hand from the handle at which time it will return to the original static position number 1.
4. Moving the handle in the direction of position number 3 until it reaches resistance, then apply more pressure until the handle "detents" to a further position. This position is retained by the detent even after removing your hand from the handle. This position "floats" the attached cylinder, allowing fluid to freely flow back and forth. This position is used to allow a snow plow to ride over uneven ground or in the case of a loader bucket, you can back drag the bucket, smoothing uneven ground without lifting the front of the tractor or lifting the bucket off the ground because of changes in elevation. To get out of "float" position you simply return the lever to position number 3 and let go. The lever will rest in position number 1.
I'm guessing all marketed loader systems will have the "float" feature controller for the bucket lift circuit.
Thanks for the information. I'll check it when I get home if the severe weather holds off! Big T-storms predicted in the midwest today. :eek:
Checked my tractor controls last night and the "detent" was there just as described. Thanks again for the good information!
   / Float feature- how do I know? #6
Am I correct to a assume a BX24 has the float option?
   / Float feature- how do I know? #8
...and so does the B7800, for those who wonder but are afraid to ask.
   / Float feature- how do I know? #9
I read that the bx23 has the float feature, but it doesn't seem to have the detent that will hold it in the "float" position. Does the bx23 have the detent? I have to hold the lever up to keep the blade in the float position on my bx23
   / Float feature- how do I know? #10
Sounds like something wrong to me...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
