Flatbed
/ Flatbed #21
Thanks guys for the input and ideas. I think some of you are right, in that the truck is just too small to use for a dumper. I keep it because I bought it new in 95 and paid cash for it, and it's been ultra-reliable ever since...it's like a "friend" now!
Why not a dump trailer ? If you throw some fertiliser bags in the back of the Ranger for stability, it will pull a 1 ton dumptrailer wont it ?
Plus, you never have to brush your truck bed before you load groceries in it, after dumping a load of dirt, and if the ranger dies, its easier to convert the trailer than a custom built dump body.
/ Flatbed #22
Theres a man that has a 95 ranger nearwhere I work. He has a little dump bed made from 3 inch channel. He has a header lift cylinder off a JD combine to dump it. The bed has no sub frame. Its got heve shing plates bolted to the frame . He has a small mowing service and hauls brush with it and trash. I think its a short bed model to.
/ Flatbed
I'm sure it would pull a 1 ton dump trailer. That is probably the best option I have right now. Plus the dump trailer could be used on other trucks, that's probably the best idea both for capacity and financially.
/ Flatbed #25
HTT, I think your right, the ranger isn't going to hold enough to make the project worthwhile.
My solution is bins. I use a 5X10 trailer I can load with forklift ready bins. The pickup location loads the bins with their loader. When I get back home with a load, I use my loader and forks to lift and dump the bins where ever. The nice thing about this setup is I can pile a lot higher with my loader than I can with a dumping trailer or truck.
I did the bins and trailer for several years. This year I lucked into an old chevy 1 ton with dualies and a long dump bed. But even the one ton does not have tremendous capacity. And if I am towing the trailer, I find it's faster if I use bins in the truck because I can unload the truck from the side without unhooking the trailer. Then I can take advantage of the pile it high option, too.
2022 EZ-GO ELITE...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2015 Ford Edge SUV (A64557)
2015 Ford Edge SUV...
3143 (A63117)
3143 (A63117)
UNUSED SDLANCH STORAGE RACKS (A65055)
UNUSED SDLANCH...
