Flat tire repair
   / Flat tire repair #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
I have a UTV with low mileage all terrain tires (non Slimed) and have discovered a flat caused by a 4-5 penny nail which penetrated through one of the center 3/8" +- raised treads. Should I repair it with the glue and synthetic twine-like product, a rubber plug or? Not sure how thick the balance of the tire casing is and I don't know if the plugs are available long enough. Please if you can, include your recommended product's brand name. I have an air compressor so I don't necessarily think that I need the hand pump type kit but maybe I do. Your thoughts please.
   / Flat tire repair #2
I have used Slime tire plug kits on all kinds of off road tires with 100% success.
Tractors, ATV's UTV's etc.
   / Flat tire repair
Thanks timswi, do I need to get a certain length of plug? Same size as the penetration or longer? A mixed package?
   / Flat tire repair #4
The ones I've bought are all the same size. They are plenty long enough for ATV and small tractor tires. AutoZone/pep boyes etc all have them. Brand doesn't really matter.
They come in a kut with the roughing tool, intallation tool, inserts and glue.
I always have a set or two laying around. They're cheap.
Some people like to put slime in the tires. That is a great solution except some tire shops surcharge you if that stuff comes splashing out. It's can make quite a mess.
   / Flat tire repair #5
I recently used the slime kit on my ZTR exmark (13psi rear tires) and it worked well. In addition I slimed the two rear for future insurance. The plugs are an easy quick fix without taking the tire off the rim.
   / Flat tire repair #6
I, too, have used the plugs for many off-road tire punctures, also with 100% success. Mine just happen to be Slime brand but I don't think that matters a bit. As long as you find the tools, glue, and plugs at an auto parts store or WallyWorld you'll be good to go.
I've plugged car tires, too. That might be a no-no, but I've never had a failure with one of them, either. YMMV
2012 TCTC 18' Trailer (A50121)
2012 TCTC 18'...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Bad Boy 747cc Outlaw **Does Not Run** (A50121)
Bad Boy 747cc...
