Flat head 6 chrysler
/ Flat head 6 chrysler #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Have an old tractor. I didn稚 have a chance to look at it just yet other then to move it before I left for 3 weeks. But I notice there痴 no power to the positive side of the coil. The inline fuel pump that connects to the positive terminal of the coil, and the wire also connecting to the positive terminal of the coil coming through the voltage regulator does not have power. I had to run the fuel pump from the battery post as well as a wire to the coil to move it out of the way. It cranks over but because no power going there unless it痴 straight to the battery it won稚 start.
/ Flat head 6 chrysler #2
A lot of those old Chrysler flatheads were positive ground. Just a thought.
/ Flat head 6 chrysler #3
check both sides of the coil with key on. one should be hot. pull the cap and see if there is spark between the points when you manualy operate them.
/ Flat head 6 chrysler #4
btw if there is a point issue replace the points with a Pertronix conversion. last problem you will have with that
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2022 EZ-GO ELITE...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
