Flat head 6 chrysler
/ Flat head 6 chrysler #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Have an old tractor. I didn稚 have a chance to look at it just yet other then to move it before I left for 3 weeks. But I notice there痴 no power to the positive side of the coil. The inline fuel pump that connects to the positive terminal of the coil, and the wire also connecting to the positive terminal of the coil coming through the voltage regulator does not have power. I had to run the fuel pump from the battery post as well as a wire to the coil to move it out of the way. It cranks over but because no power going there unless it痴 straight to the battery it won稚 start.
/ Flat head 6 chrysler #2
A lot of those old Chrysler flatheads were positive ground. Just a thought.
/ Flat head 6 chrysler #3
check both sides of the coil with key on. one should be hot. pull the cap and see if there is spark between the points when you manualy operate them.
/ Flat head 6 chrysler #4
btw if there is a point issue replace the points with a Pertronix conversion. last problem you will have with that
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2020 Solar Tech Silent Advisor S/A Solar Towable Radar Trailer (A61572)
2020 Solar Tech...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
