flat faced quick disconnects issues
/ flat faced quick disconnects issues #21
Is this true with other brands of connect under pressure?
/ flat faced quick disconnects issues #22
As far I know, yes. But I'm not an expert on all brands.
This is my understanding, let me know if I seem to have something wrong.
If you have pressure on one side, and the coupler on the pressurized side allows you to connect under pressure, that pressure is safely transferred into the mating coupler when you connect the two halves together. If you have pressure on both sides, there is no way to release it, and the couplers cannot be connected.
/ flat faced quick disconnects issues #23
The Parker 8200/9200 Series QD can be connected, with both sides under pressure.
Some of the others will connect up to 500 psi .
/ flat faced quick disconnects issues #24
My bad. I thought you were only asking about flat-face couplers.
There are some other couplers that connect under pressure. Wet Line Couplers (wing-nut style) and 10,000 psi Screw Together Couplers (Enerpac C604 Interchange) will also connect under pressure, and I think they can all be connected with pressure on both sides.
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2022 EZ-GO ELITE...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
