flat faced quick disconnects issues
   / flat faced quick disconnects issues #1
Rio_Grande
Platinum Member
Have any of u had problems with these lasting? I am on my second set now. first set i just plugged in and went, second set I cleaned every time I used them, Even kept a rag in the skid steer to do it.
The first set just started leaking and wouldnt stop. This time it is the female coupler and it will not lock onto the male without smacking it with a block of wood, which at the cost of the components is not acceptable. There dosent seem to be way to service or clean these. At 80.00 for the female connector I am starting not to like these.
Anyone have any other experience with them or advice on how to get them to last?
   / flat faced quick disconnects issues #2
First of all, why are you paying $80 just for the female connector? Are you using a larger than normal size? ISO 16028 flat face couplers with 1/2" (nominal size) bodies, the most common size, are readily available for about $50 per set.
We sell at least a dozen sets a week here, and we haven't seen any more problems with these than with any other couplers.
Our most common complaint with any coupler has been "they leak" and almost every time, the leak disappears as soon as we flush them out on our pressuring testing equipment.
   / flat faced quick disconnects issues #3
Some of the manufactures off rebuild kits for the QD's. That does seem kind of steep for the flat face connectors. Some people also go the next larger size to compensate for the reduction in flow. If you shop around, you can fine them with a great price difference. Did you particular want flat face QD's? Yes, they are easier to keep clean, and no, they all do not all connect under pressure.
After reading this thread I did a bit of pricing around and you are right I was getting hosed.
I never could find them anywhere but my local hydro shop. Called the company who sold me my skid steer and they had them for 30ish for the female connector.
Seriously the hydro shop down the road from mom and dads hit me for 80.00 pluss some tax for one female connector little over a year ago. We were broke down because of the fitting and I had to do something.
I had seen them on ebay cheap but figured they were not as good as the last one I had bought. Glad my dealer has them and takes care of us.
I am sure the hydro shop has a flow tester but what are they gonna charge to put it on.
I didnt especially want this style connector but it is what my loader uses.
   / flat faced quick disconnects issues #6
Just as an FYI, I probably sell more flat face quick disconnects on eBay than any other seller. Chances are the listing you saw there was one of mine. -laughs-
   / flat faced quick disconnects issues #7
We use them at work and are not impressed. We have seen these be bad right out of the box - brand new. On more than one occasion we have seen them go bad on the return line which blocked the flow and promptly blew the seals out of the valve we use in our equipment. On a couple of instances it bent the spools in the valve. The old round ball fittings were cheaper and lasted much longer. I highly recommend changing out to those.
Justin
   / flat faced quick disconnects issues #8
Listen to Hydraulic Hose Guy. He is right on. I have had the exact same experience except I can't come close to his price.
Not meaning any disrespect there is just alot of cheap crap out there and alot of it is on ebay. Can us send me a link to one of yours? I like buying off of stand up folks. Gonna need spares just in case this one goes out.
Jeff
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
2013 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A53426)
2013 VOLVO...
2011 Toyota Sienna AWD Van (A51694)
2011 Toyota Sienna...
Kobelco MD 200B LC Excavator (A52384)
Kobelco MD 200B LC...
