Flashlights
   / Flashlights #11
I have a 2 Streamlight flashlights. One is a full-size (14 in) rechargeable (battery pack is size of 3 d-cells)... 30,000 candlepower ($100.00). I've used this one for 22 years.
The other is about 8 inches long (battery pack is like 2 d-cells) 15,000 candlepower ($75.00). I've had it about 4 years now.
I do not use regular battery-type flashlights... they are not bright enough. My life might depend on the amount of light I have available.
These can be bought at most uniform shops that carry police and fire uniforms. Galls might have them.
   / Flashlights #12
I'm a fan of the Maglites. I have a 4 D cell next to the seat of my Tahoe and another just inside the back doors. I keep a 6 D cell at home atop an open shelf so I can find it in the dark when (not if) the power goes out.
I do understand the rechargeable are quite a bit brighter and that there are some LED lights that are quite bright, too.
   / Flashlights
Would a rechargable light verses a battery light (both starting from full charge) last longer?
I guess I was presuming the rechargable would tucker out first... am beginning to think I'm presuming wrong.
(am just glad I was not "assuming")
/forums/images/graemlins/wink.gif
   / Flashlights #14
Depends....
The more candlepower, the quicker it dies.
The advantage of rechargeable is within a few hours, it's ready to go again. And like cordless power tools, you can get extra battery packs and always have a couple fully charged.
   / Flashlights #15
   / Flashlights #16
Richard,
In flashlight applications, Alkaline Cells will outlast Nickel Cadmium about 3:1. The Nickel Cadmium can supply much higher currents than the Alkaline. Alkaline would not be suitable for really high power application like spot lights. A "D" cell Alkaline has a short circuit current of a few amps. A "D" cell Nickel Cadmimum has a short circuit current of ten's of amps.
   / Flashlights #17
One thing you might look at is the various lights out there that come with rechargeable drills or saws. I thought they were a gimmick at first, but after receiving a Porter Cable 19.2 volt as a gift to go with my drill and saw, I was hooked. They put out a lot of light, easily that of a maglight, and when they start to go dim, just drop another battery in them.
If you already have the cordless tool system, the cost is minimal. If you don't get an 18 volt drill, saw, and light at sears for the cost of the rechargeable maglight. That's what my buddy did, and his light seems to work just as well as mine.
Oh, one other thing. The flat base formed by the battery makes it easy to set down and remain stable. Then the light can be aimed where you want it.
   / Flashlights #18
My 9v Makita nad 18V DeWalt lights are great! They easily outshine my 2 and 4 cell Maglites(which I like too...). The DeWalt is kinda clumsy for use out in the field.
I have the DeWalt car charger. I use the 18V when camping and stuff. I have three batteries, so I always have a fresh one.
   / Flashlights #19
Most rechargeable lights use NiCad cells. Some now use the lithium or lead acid type gell cells. The rechargeable type batteries, especially Nicads have very low internal resistence and therefore can produce higher amperage than alkaline cells. These coupled with a higher wattage bulb causes them to be much brighter but with a generaly shorter burn time before recharging. The D cells Nicads in industrial capacity are up to 4 or 5 amp capacity vs the ones from Wally World at about 1.2 amps capacity. With a known current draw from your bulb you can calculate the actual burn time from a fresh charge by dividing the draw from the bulb into the battery capacity. The low internal resistence of a Nicad is why if you put one in your pocket and your keys short it out it will burn a hole in your pants--yeah--they will--I know /forums/images/graemlins/shocked.gif. Alkaline non rechargeable cells have a high capacity but the internal resistence is much higher so they burn much longer producing a much lower amperage over a longer time thus they cannot be as bright as a quality rechargeable light.
Some of those 1,000,000 candlepower lights that can be had for less than 30 dollars actually work very well, use a 25 to 55 watt qrtz halogen. I think a 55 watt bulb of that type--H3 draws about 5 amps at 12 volts. I could be wrong about that exact number but you can see that you need either a big battery or must suffer a short burn time, one or the other.
I have a dive light I made --I built it--machined from aluminum 2024T3 billet and Plexiglass for cave diving that uses the Nicad liquid cells from the batteries that start jet turbines. These battery packs are composed of many individual cells, each about 1.2 volt but they have tremendous capacity. I run two 55w Halogens for redundancy, each individualy switched so I can run either or both. I can run two 100w bulbs as well but the run time drops to about 45 minutes. I built a few of the lights after so many wanted them and sold them for 1200 dollars but at the time I was a higly paid geologist and did not care to start a buisness--hmmm, maybe now that I am less highly paid I could revisit that idea--nah--I prefer sitting on the porch and shooting at Yankees, man o man, I can shin'em up good with that dive light /forums/images/graemlins/shocked.gif.
There is a new type of lighting system available--very expensive -- and very birght and uses very little power--HID--High Intensity Discharge. A transformer of sorts delievers power to a bulb that uses an arc rather than a filiment--like a welding torch--very bright blue light. Some cars, aircraft and special purpose lights use them. There are now small handheld flashlights but I bet they could run 400 dollars. J
   / Flashlights #20
Speaking of paying too much....
I am a flashlight NUT, always looking for the coolest new light (ya, I'm weird). So I'm watching the X-Files TV show, and they are in some dark place with all that smoke that seems to be around 'em all the time, and they have these COOL lantern style lights with these massive spot beams! I gotta have this!! I've seen 'em on a bunch of cop/fireman/military shows, so I figure I will get one...
HA!!!!! After much research, I discover it is called "The Maxa-Beam" by The Current Corporation.
"A high intensity Xenon searchlight originally designed for military search and rescue missions: The MaxaBeam™ uses a unique short-arc Xenon lamp which creates a six million candlepower beam of white light. The 3.2 pound (156 gram) unit provides sufficient light to read a newspaper from a distance of one and a half miles."/forums/images/graemlins/cool.gif
Sells for between $1300-$2000 bucks!! I guess I ain't gettin' that one, but our FBI gets 'em!! (Like Mulder needs a 6,000,000 candlepower flashlight!!)
/forums/images/graemlins/grin.gif
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
