Flail V belts
   / Flail V belts #1
No1umfan
Massey ferguson 135
I need to replace the V belts on my Ford new Holland 918 H flail mower. The specs call for a 5/8 x 48.8 cm belt. That’s obviously a hard belt to find. Am I better off going with the 48 inch or 49?
   / Flail V belts #2
Centimeter or inch? :)
I would do the 49" belt.
   / Flail V belts #3
49" should work fine. Look at the adjuster on the mower, you should be able to determine if you have more adjustment to tighten the belt. If you have quite a bit, then the 49" is the one
   / Flail V belts #4
5/8" belts are "B" belts. A 49" outside diameter is a B46. A B49 belt has an outside diameter of 52". Easy to find online. I found I had to crank the tension pretty high on my flail mower to keep the belts from slipping and self destructing. You can also buy a matched set that are exactly the same length. Apparently most belts can have minute length differences and thus the tension would not be exactly the same. I didn't find this to be a problem though.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
Honda EM3500S Generator (A55851)
Honda EM3500S...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
John Dozer JD650 (A51691)
John Dozer JD650...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
