flail mowers waist HP?
   / flail mowers waist HP? #1
8404
North Mississippi
Cub Cadet 8404 or DK 40 Kioti
I have read every post on opinion of flail mowers vs rotory cutters, and the one thing that seems to be unclear to me is that some say the flail uses up more HP than the rotory cutter and others said that you can cut a wider path with less HP with a flail. so which is it? will a tractor use more of its HP useing a 7 foot rotory or a 7 foot flail cutter is feild grass.?
   / flail mowers waist HP? #2
Depends....Flails typically require a slower ground speed than a rotary of same width, especially so in heavy weeds/grass. The only way to equalize "acres per hour" between the 2 would be a tractor of more HP for the flail, OR, accept the fact they won't mow as much per hour with same tractor. Of course, all depends on what you're mowing....Just trimming a well manicured lawn, neither will tax a motor too much, so the point is moot. Slow down ENOUGH, and you could mow with a much wider mower of EITHER type without additional HP.
Once you go to very wide mowers, (ie 15' bat wing vs rear & side mounted flails) the hp demand goes VERY one sided, as side mounted (wing) flails are USUALLY hydraulic driven and the power demand can jump quite a bit.
Again, in "minimal" conditions, such as a regularly mown lawn, pasture, ect, the difference is hardly a consideration.
BTDT, tried 'em both....Not at all impressed with flails in the condition I HAVE TO MOW IN. (Too slow/too costly/too high maintenance) YMMV. Consider MOST people aren't mowing highway ROW's though...I AM. I'd probably be more satisfied with a flail if all I cut was my yard or well groomed pastures.
I'm sure Leonz will be along shortly to tell you why not using a flail mower will cause your property to be infested with rats and poison ivy....;) Take that with a grain of salt.....
Beware of advice that paints a picture of one or the other being "THE ANSWER" to every situation. NEITHER will do everything in every case. Some people are simply too biased to give a fair and objective point of view.
   / flail mowers waist HP? #3
Everything I saw in FWJ answer indicates that a flail uses more power per width to keep up with a bushog. Dont know why he didnt just go ahead and say it. Mine sure makes the tractor work harder. Those that say you can cut a wider path with less HP are wrong or else mislead by not drawing out that work is HPHrs-not HP. This distinction is implicit in the FWJ post.
larry
   / flail mowers waist HP? #5
What the guys are saying above is not the whole story. Most (if not all) flails are belt-driven. Rotary cutters are not. Whereas going through heavy stuff with a RC can bog down the tractor engine, going through the same stuff with a flail will just generate smoke as the belts start slipping. More horsepower cannot do anything about that.
I have both; a 60" Kodiak RC (medium duty) and a 74" Ford flail (heavy duty), both of which I use for pasture maintenance - behind a JD3720 (35 PTO hp). But given my mowing conditions, I much prefer using the wider flail, but there are several spots of heavy stuff (winter livestock feeding areas) that usually make the belts slip. I've learned to bypass those areas with the flail, and come back later and get'm with the RC.
//greg//
   / flail mowers waist HP? #6
//greg//
There is something either wrong with that belt drive or there is a design issue. My 60" Rears flail, as delivered, and still, will bog a 50HP tractor with no smoke and no notable belt heat. Final drive is a tandem B belt 2/3 increaser tensioned by pulley spacing not idler. I have not had to adjust it.
larry
   / flail mowers waist HP? #7
Given the fact that there are likely several hundred thousand Ford 917H flails still in use, I'm disinclined to agree with "design issue". It's a twin pulley drive, on which I use a Kevlar reinforced double (banded) v-belt.
I've also owned a few PTO finish mowers over the years - obviously belt drive as well - and they all exhibited belt slippage in heavy stuff. Can't say that I've ever even heard of a Rears, so forgive me if I'm inclined to skepticism.
//greg//
   / flail mowers waist HP? #8
I havnt heard of a Bears either. A 74" Heavy Duty flail belt slipping in anything but a quick stall on a 35HP tractor is a serious out of spec issue. - Pulleys worn or bad tension probably. - If that actually is a norm then it is a prevalent bad design issue. Sure glad I dont have a Bears, or a Ford 917H. Finish mowers are another issue, totally undefined here as to size vs drive power, and consequently not relevant in any shown way.
larry
   / flail mowers waist HP? #9
Spyder, I think the "Bears" greg_g is talking about is where you say, "My 60" Rears flail..." He said "Bears" instead of "Rears."
   / flail mowers waist HP? #10
larry
Old debating tactic....
It's called "baiting your opponent"....;)
   / flail mowers waist HP? #11
The typical flail mower or flail chopper has more cutting edge surface exposed to the grass or brush versus the rotary cutter of any cutting width width as the rotary cutters exposed cutting edge is in actual use half of the mowers width with one mower blade always trailing the first advancing blade.
The flail mower or flail chopper has many more feet of cutting edge exposed doiing the same work at a higher speed of rotation at all times as the flailmower rotor is spinning at a much higher RPM due to the V belt drive or gear drive of a flail chopper.
If anything the flail mower has a higher efficiency simply because it has more cutting edge exposed doing the same work along the entire width of the mower at work.
Each grass slicer or scoop is cutting a small pottion of the grass ahead of it and the grass slicers, scoops, duck bill hammer knives or hammer knives following behind them overlap and remove the portion that is left as the mower advances or reverses with the prime mover.
The flailmower is not an energy hog as the individual knives are using the throw wieght of the knive, knive hanger and rotor as the entire assembly is rotating about axis of the rotor.
In the case of the Mathews Company Lawn Genie and and other European makes of grass mowers with collectors, the rotor consists of a very large
weldment that welded to make a large diameter tube not quite resembling a lawn roller with swiveling metal paddles attached to create additional suction along the entire width of the rotor and also add throw wieght to the rotor shaft that it is attached to to make more efficient use of the grass slicers and dethatching blades in our case.
In our case the flail mower is doing more work per foot of cut with more grass knive edge exposed with the same power as the 60 inch Lawn Genie Pick up mower which is P.T.O., powered as it is rotating the the air paddles to move the grass over the rotor and into the hopper or back down to the ground in the case of heavy brush for pick up later if desired.
In the case of flail choppers the scoop knives act as an air paddle at the same time they are shredding the cotton, cane, corn or potato vine stubble left after harvest.
The flail is not wasting power when used at the 540 R.P.M. speed as the rotor is traveling at a greater velocity than a rotary brush cutter of any size as the throw wieght is used to mow along the entire width of cut with the grass slicer knive, hardened grass slicer knive or grass scoop, duck bill type of flailhammer or a flail hammer as the entire width of cut is utilised at all times.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
   / flail mowers waist HP? #12
Each grass slicer or scoop is cutting a small potrtion of the grass ahead of it and the grass slicers, scoops, duck bill hammer knives or hammer knives following behind them overlap and remove the portion that is left as the mower advances or reverses with the prime mover.
.......And now for the comedy portion of todays program.............:)
Puts me in mind of the last "State of the Union Address". ;)
   / flail mowers waist HP? #13
Seems the bait has been taken!!
   / flail mowers waist HP? #14
Cant... resist... must... jump in...
A rotary cutter arguably uses half the blades at any given time to do the work. Got it.
The flail is more efficient because there is more cutting surface employed at any given time??? Let's see... It's a spinning drum. The knives are attached to said drum. The drum is set at a position parallel to the ground. The knives cut at the lower point of the swing. How much of the lower portion of the drum is low enough to be used? Perhaps 20-25%? The other 75-80% of the time, the knives are spinning around the front, top and back of the drum without cutting anything. Sure, you can argue the knives are shredding the grass, but you can also set up a rotary cutter to shred the grass.
Then there are the inherent friction losses of belts vs. gears. :confused2:
The way I see it, the RC is roughly 50% efficient, while the flail is only 25% at best; probably closer to 20%
Now I've done it! :D
Joe
   / flail mowers waist HP? #15
At any point in the rotation of the rotor, the entire width if the rotor whether it has 3 or four rows of grass slicers has one full width of grass slicer slicing the grass.
Using a 48 inch rotor with 4 rows of grass slicers in the example each row will have 16 pairs of grass slicers and a single grass slicer at opposite ends of the rows covering the entire 48 inch width the following row is opposed in the lacing covering the next portion to be sliced with the following two rows continuing the coverage.
Each knive has 1 1/2 inches of slicing edge exposed to the turf or brush with 3 inches of cutting edge per hanger with 16 pairs of knives and an extra knive provides the row with 49 and 1/2 inches of cutting edge to be used for the 48 inch width. so the flail mower has 199.5 inches of exposed cutting surface versus 24 inches in a finish mower or rotary cutter which is doubled if you count the unexposed edge on the back side of the grass slicer knive.
   / flail mowers waist HP? #16
Not quite, at least on mine. The hammers aren't in straight rows, they rotate around the tube. If you could connect the hammers the line would look like threads on a screw. Sort of like a reel mower broken into segments.
I never really checked it out to see how many cut at any given time, I would guess 4 because there are 4 rows of hammers.
   / flail mowers waist HP? #17
Its hard to visualise but think of a a rototiller digging up the ground in the same way as the tiller blades overlap from side to side on the same axis as well.
   / flail mowers waist HP? #18
Simply put, a 48" rotary cutter will have 48" of matter cut with one simple blade moving in a continual arc from one side, around the front, and to the other. Literally, 50% of the available cutting surface is always at work. What percentage of available cutting edges are at work at any given time on a flail?
Joe
   / flail mowers waist HP? #20
Joe
if you have a 48 inch width rotary cutter only one blade is cutting with the other following at all times allowing 24 inches of exposed cutting edge
A flail mower wil have one hundred percent coverage per my previous explanation as the grass slicers overlap due to the grass slicer becoming an airfoil becoming horizontal and achieving the zero degree angle from its fourty five degree angle at rest.
This does not occur on some brands of flail rotors as the knives are restrained vertically and there is a longer cutting edge per knive which eliminates the need to allow the knive to become an airfoil and achieve a zero degree angle.
1454 (A57192)
1454 (A57192)
207278 (A52708)
207278 (A52708)
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61306)
Bulk Lot of over...
