Flail Mower Flail mower versus mulcher?
   / Flail mower versus mulcher? #1
Redfox
What is the difference between a flail mower and a mulcher?
   / Flail mower versus mulcher? #2
A flail mower is used to maintain areas that you would normally bushhog with a rotary mower. A mulcher is used to clear areas that has good sized trees or stumps, you would tear up a bushhog or flail mower. A bushhog and flail are a closer match. Flail mowers have blades that swivel and mulcher blades are fixed on a drum.
   / Flail mower versus mulcher? #3
A flail is a heavy duty mower..... heavy grass, saplings, etc....
A mulcher is like the nastiest rototiller you've ever seen, on steroids, and with a very, very bad attitude!!! Google search "ironwolf slasher" and watch the videos!! They're the extreme, but you'll get the drift.
-Jer.
   / Flail mower versus mulcher? #6
Did you mean a mulching mower?
   / Flail mower versus mulcher? #7
That much I know. :)
The real questions is:
Is a Mulcher just a really big and beefy flail mower, or are there other differences?
The $17,000 3-point mulcher is only 48" wide and weighs more than a ton. It will probably mow grass just fine but it is pretty inefficient running a tractor that can haul that much on the 3ph (like the one pictured) to do the job of a 20hp machine, let alone the sacrifice in maneuverability.
   / Flail mower versus mulcher? #8
More like a gang of stump grinders than a flail. They tend to have solid non pivoting cutting edges rather than pivoting knives or hammers like a flail mower.
   / Flail mower versus mulcher? #9
First picture is a flail mower. Second picture is the blades on a flail. Third picture is the cutting/mulching head on a mulcher. Last picture is a heavy duty flail axe. It will chew up to 2 in, trees, but leaves a lot of debri left over.
A flail mower can also have a thick chunk of sharpened steel to rotate around ,and flail the he** out whatever.
Thanks guys. Now I understand.
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
2014 Wacker Neuson BS50-4s Jumping Jack Plate Compactor (A55851)
2014 Wacker Neuson...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
