Flail Mower Flail mower versus mulcher?
/ Flail mower versus mulcher? #1
Redfox
Member
What is the difference between a flail mower and a mulcher?
/ Flail mower versus mulcher? #2
A flail mower is used to maintain areas that you would normally bushhog with a rotary mower. A mulcher is used to clear areas that has good sized trees or stumps, you would tear up a bushhog or flail mower. A bushhog and flail are a closer match. Flail mowers have blades that swivel and mulcher blades are fixed on a drum.
/ Flail mower versus mulcher? #3
A flail is a heavy duty mower..... heavy grass, saplings, etc....
A mulcher is like the nastiest rototiller you've ever seen, on steroids, and with a very, very bad attitude!!! Google search "ironwolf slasher" and watch the videos!! They're the extreme, but you'll get the drift.
-Jer.
/ Flail mower versus mulcher? #7
That much I know. :)
The real questions is:
Is a Mulcher just a really big and beefy flail mower, or are there other differences?
The $17,000 3-point mulcher is only 48" wide and weighs more than a ton. It will probably mow grass just fine but it is pretty inefficient running a tractor that can haul that much on the 3ph (like the one pictured) to do the job of a 20hp machine, let alone the sacrifice in maneuverability.
/ Flail mower versus mulcher? #8
More like a gang of stump grinders than a flail. They tend to have solid non pivoting cutting edges rather than pivoting knives or hammers like a flail mower.
/ Flail mower versus mulcher? #9
First picture is a flail mower. Second picture is the blades on a flail. Third picture is the cutting/mulching head on a mulcher. Last picture is a heavy duty flail axe. It will chew up to 2 in, trees, but leaves a lot of debri left over.
A flail mower can also have a thick chunk of sharpened steel to rotate around ,and flail the he** out whatever.
Thanks guys. Now I understand.
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
