Flail Mower on a Toolcat 5600
   / Flail Mower on a Toolcat 5600 #1
TexOnt
Quinte West ON Canada
Toolcat 5600 & International 2444
I recently bought a Flail mower (GIYI model GY-FM57) "Y' Blades. Hooked it up, roller adjusted and I have a question for one of you experts out there that knows way more than I do. Regardless of what I do it will not Mow ANYTHING. Tried Short grass, tall Grass, Low Speed, High Speed Nothing. Blades spinning Ok Just not cutting at all. What am I doing wrong? Appreciate all comments and solutions you may have. Thanks
   / Flail Mower on a Toolcat 5600 #2
Are the blades spinning in the right direction?
I have a wood chipper that I have to reverse the flow by using the trigger and toggle because everything else runs on the default flow direction.
Interesting you mention that. Both my wife And I thought they were not spinning in the proper direction.
If you stand on the right side of the machine looking across the mower the shaft is turning counter clockwise. To us we thought this was wrong.
If it is wrong how do I reverse the flow? Thanks
   / Flail Mower on a Toolcat 5600 #4
While holding down the trigger on the back of the joystick, Push the middle toggle control to the right and release the trigger, and the flow should now be reversed -
Thanks, When We initially tried to use the mower The toggle did not seem to do anything when holding to the right and using the trigger underneath the Joy Stick so we used the toggle to the left annhen the trigger under the joy stick and it activated the shadft with the blasdes
Thanks Admirals We will go try as you suggest and see what happens
May be a bit before We do it as have something else I need to deal with first
We just tired as suggested.
Held the trigger on the back of the joystick
Pushed the middle toggle to the right and released the trigger
It did not change the rotation of the shaft on the mower from counter clockwise to clockwise.
I also tried pushing the middle toggle (only one on my model) on the joystick to to the right and then holding the trigger just in case that might work.
Nothing. There does not seem to be any way to reverse the rotation of the mower shaft.
I know there is nothing wrong with both the left and right toggles as I was just using a grapple bucket and all winter I use a blade plowing so I know both left and right toggles work OK,
Any other suggestions to reverse the spin of the flail mower shaft from counter clockwise to clockwise
Appreciate any suggestions
   / Flail Mower on a Toolcat 5600 #8
What happens if you push and hold the toggle to the left then push the trigger?
This is what my joystick looks like:
John Deere 772-A Grader (A52384)
John Deere 772-A...
2024 JOHN DEERE 6110M LOT IDENTIFIER 115 (A53084)
2024 JOHN DEERE...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2007 50FT 3 CAR HAULER TRAILER (A53426)
2007 50FT 3 CAR...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
