Oil & Fuel Fixing that BX Fuel Tank Leak over LH Tire
   / Fixing that BX Fuel Tank Leak over LH Tire #1
nosplace
So whats the final solution to fixing the LH Gas Tank leak. Are the fuel sending kits K2561-96140 fixing this problem? Also do you have to remove the Roll Bar to get to the top of the tank?
Thanks in advance!
   / Fixing that BX Fuel Tank Leak over LH Tire #2
As I recall, my initial investigation to find out what was leaking showed that removing the ROPS was necessary. Additionally I think I removed the fender. Those were easy things to do. I did not install "The Fix" because I traded-in the BX2200 that exhibited the problem. If you do a search about the fuel tank leak I would imagine that you'd find quite a bit more info.
   / Fixing that BX Fuel Tank Leak over LH Tire #3
The kits I have installed, have fixed the problem. You do need to remove the ROPS and left fender to get to it.
J.D.
Went into the dealer today and I was going to ask for the part free but they said to bring the tractor in and they will fix it for free parts and labor. I justed purchase it used (BX 1800) yesterday so that may have something to do with it. /forums/images/graemlins/laugh.gif
   / Fixing that BX Fuel Tank Leak over LH Tire #5
part is cheap and nothing to fix. The major pain is getting to it.
About 1 to 1.5 hours job.
   / Fixing that BX Fuel Tank Leak over LH Tire #6
I see no one has welcomed you to TBN. /forums/images/graemlins/blush.gif
Welcome. /forums/images/graemlins/smile.gif
<font color="blue"> they will fix it for free parts and labor </font>
Thats the kind of thing I like to hear every time I go to a dealer. /forums/images/graemlins/cool.gif
What part of the country are you located in?
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2014 Doosan DA30 (A53472)
2014 Doosan DA30...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
1264 (A50490)
1264 (A50490)
