Fixing Stabilizer Cylinder Leak
/ Fixing Stabilizer Cylinder Leak #1
JoelD
Veteran Member
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Hi all, had a scratch in rod and ruined seal.
I'm looking to replace the Dust seal and the other two seals within the head that the scratch likely mucked up.
The manual has the seals as 35x43x5/6.5 for the dust seal, which I think I found on Alibaba.
I'm now looking for the Rubber and Urethane seals 35x45x6.
Is there anything I should be searching for in particular? Not sure what terminology to be using when searching?
The manual does not refer to them as o-rings, rather they are referred to as "retainer", one rubber and one urethane.
Any assistance in locating is much appreciated.
From experience when I try to purchase such things through dealer the prices are silly high, I replaced all o-rings in my backhoe valve body for under $20 total, when dealer was charging $20 per o-ring. Seriously, $20 per.
Joel
I did search on the part number and cub cadet looks to have same parts
Found online for reasonable price
Never hurts to search on part number
LOL
Would still like to find alternative source
Joel
/ Fixing Stabilizer Cylinder Leak #3
Any hyd shop should have the seals and o rings in stock.....
/ Fixing Stabilizer Cylinder Leak #4
I looked here to get the OEM numbers to check my big cross reference book, but they're not in there. Must be too new, but you can search for them.
Well flyer there they are listed In your link! I was trying to be too fancy!! Thank you!!
