Fixing ruts?
/ Fixing ruts? #1
cdnt
I was bush hogging around the outside of a field/ orchard and managed to hit a very soft spot (too much rain) on a relatively steep uphill section. Loaded ag tires needed 4x4 and diff lock to keep moving. Damaged section is about 15 to 20 feet with ruts about 1foot deep but wider than track as I had to turn to get out, slipping, etc.
Any thoughts on how to best repair? Use loader / blade to fill in and then plant something?
Cheers
/ Fixing ruts? #2
Catch it when it is starting to dry out but is still moist enough to crumble easily in your hand. Then use your bucket to backdrag and smooth over the ruts.
You can seed it if you want but I suspect it would grow back on its own.
/ Fixing ruts?
Thanks Steve that sounds like good advice. At this rate with All the rain, it will be September!
/ Fixing ruts? #4
Wait till it dries up and drive down the high points on either side of the rut to flatten it out.
/ Fixing ruts? #5
If you wait until it si COMPLETELY dry and you wont create more ruts, my perfered method is
Use a back blade angled as steeply as you can. Straddle the rut and drop the blade. This will roll dirt from one side back into the rut, but it will move the dirt on the other side a little farther away. Simply turn around and hit it going the other way:thumbsup:
/ Fixing ruts? #6
You have to replace at least as much soil as what came out stuck to your tires.:laughing:
Somehow, in defiance of all known laws of physics, some ruts never have enough dirt around them to refill completely.
Dave.
/ Fixing ruts? #7
weve had some success fixing ruts with a 3pt tiller.but you may not have a tiller.
/ Fixing ruts? #8
Sometimes if you ignore them, they will go away in time.
/ Fixing ruts?
Hmm lots of possible options. We do have a tiller if needed
/ Fixing ruts? #11
If you have access to a box blade you could dig up the area around the ruts by keeping the rut centered under the tractor and the box will fill the rut.
/ Fixing ruts? #12
I do like JohnDeere and use the box blade. If it's really bad, I disk over it a few times and that will re-level all the dirt...then don't drive over it until a couple rains so it will settle out and harden up again.
/ Fixing ruts?
Do you guys plant anything or just see what pops up?
/ Fixing ruts? #14
Since it rains so much here I just wait until something grows back. It usually does within 2-3 weeks.
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
