Fixing chainsaw bar oil problem with your tire pump
   / Fixing chainsaw bar oil problem with your tire pump #11
Then instead of a air pump you use a vacuum................
   / Fixing chainsaw bar oil problem with your tire pump #12
On my Dolmar there's a breather check valve in the oil tank cap. You couldn't drill a hole in it without causing problems. How does Sthil vent the tank?
   / Fixing chainsaw bar oil problem with your tire pump #13
what I would like to see is an oil tank cap with a rubber bulb built-in. So pressing or squeezing the bulb would provide enough internal pressure to break the gap in the oil flow system.
What, you mean like this? Follow the line from the cord up the handle to just before the hand guard.
Note ... a static picture you can look at and study and don't have to try and freeze at any certain point like a veeedeeeooo.
   / Fixing chainsaw bar oil problem with your tire pump #14
I've found that after a cutting session that if you loosen and then tighten the oil cap it no longer bleeds oil all over. Seems that this relieves the vacuum in the tank? Maybe the vent is plugged? not sure but it works on my saws.
   / Fixing chainsaw bar oil problem with your tire pump #15
Yomax4 it relieves the tank pressure since some high end saws have a one way valve on the oil tank. Lets air in but not out, which is what causes the pressure buildup and then leakage.
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2016 Ford Expedition SUV (A55853)
2016 Ford...
UNUSED FUTURE FT-ZP210 20' X 30' ALLSTEEL GARAGE (A57193)
UNUSED FUTURE...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55315)
Adams Load Out...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
