Fixed the hose
/ Fixed the hose #21
BobRip said:
Somebody correct me if I am wrong, but cracking of the outer covering is not an indication of imminent failure. Just under that is a metal webbing and then under that is another rubber jacket. These actually contain the pressure and stop the leaks respectively.
Bob, you are partially right that a crack on the hose is not grounds for replacement, but consider this. When you have a cracked hose, you have lost your moisture barrier. Moisture can now get in to rust the steel wire, and it almost guarantees a blowout at the rusted wire area. I have seen it happen on the PT, and I have seen rusted areas burst open on many pressure washer hose. If your hoses start to crack, you might extend the life of the hose by wrapping the cracked area with some electrical tape. On hoses left out side, UV rays will damage the rubber, and when you flex them, they will crack. An added safety margin is available by purchasing 2 wire or 3 wire hose, although not as flexible, it is much stronger.
Has anyone purchased any replacement hose from PT. I am a little curious about the quality, how many layers of steel, price, exact fit, etc.
/ Fixed the hose
I did, kinda by accident. When I had them rebuild my steering control, I felt two of the hoses where really stiff. They sent me two new ones, that were just as stiff. Lets see... small hoses, 12" or so, $35 for 2....
/ Fixed the hose #23
J_J, thanks for the information. I learn a little more each time you write.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61572)
Toyota 2FGC20...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
