First Tractor. Deere 3720???
/ First Tractor. Deere 3720??? #21
If you are tooling around with the configurator on the JD website, be aware those are MSRP prices. Expect to get 10% off those as the starting point for negotiations. If you don't have tons of experience with tractors, JD is a good starting point. The HST models drive just like a lawnmower. This leaves your focus on what you're doing with your loader and 3-point (oh and making sure you're not running into things) without having to worry about stalling the engine.
Similarl to your situation, I'm a Civil Engineer by day. I work out of a home office now on our farm (15 acres + 30 leased acres). I've never really had an issue not having work lights, since the days are so long in the summer. What I generally do is knock-off up here in the office about 3 pm, work outside on the tractor or weeding the garden for several hours, then do another hour up here before bed time.
/ First Tractor. Deere 3720??? #22
p.s. Get to know your neighbors with bigger tractors very very well. Feed them, booze them, ask them about their grandkids everytime you see them. There is no way anyone can move into a new place and have the foresight to know which attachments you may need, or not get the wrong ones. You'd spend a fortune!
So, right now, I'm cutting for silage with my brush hog set as low as it will go. My neighbor then comes down with his 125 HP JD and is bailing & wrapping it for me... for nothing, except that he likes to see people farm. So the beauty is to make friends, keep an affordable tractor to operate, then get people to do the really heavy work for you!
I just called a Kioti dealer and they quoted me over the phone $25k for a DK45s with an air conditioned cab and a loader. It is a manual trans but I'm not thinking thats a major problem for close to $8k savings over the JD 3720. It is 3 less horsepower but I'm not sure thats a huge deal.
Is this a good price? Kioti's web site doesn't seem to post msrp's like JD does so I'm not sure if this is a good number or not.
Mike
/ First Tractor. Deere 3720??? #25
Back in January I was quoted $23K for a DK45S with loader, and ROPS open platform. So based on that, $25k for the cab model sounds great. Definitely worth a look. It will be somewhat bigger and heavier than a 3720, but IMHO not too big for your uses. I believe the DK45S has a 12-speed manual trans which will give you a lot of speed options, always a good thing. Gee, if I had been able to get (or had known) about that price for a DK45S with cab, I might own one now!
one website I saw listed Kioti as "service challenged"
any foundation to that claim?
/ First Tractor. Deere 3720??? #27
That's a real good price.
I had owned a Farmall, Ferguson 30, and a JD 870 before I bought my Kioti and had no reservations at all about buying one, I liked what I saw and how they were built and so far it has lived up to expectations.
As far as speed options I am always either in 3 medium or 4 medium and probably could get along with a lot less than the 12 speed but the different gears are there if you need them. They do make a 45 hydro but you can't get cabs for them yet.
The Kioti 45 will not be as "nimble" as the smaller framed JD tractors and it does weigh a bit more, the 45 cab with loaded tires and FEL weighs in at about 6500 lbs.
/ First Tractor. Deere 3720??? #28
Never heard that expression before but I have a dealer 32 miles from my house and their dealership is top notch, as nice as any tractor dealership in the area.
Go to the Kioti dealer and see how he's set up and if you don't like what you see then head for the door.
/ First Tractor. Deere 3720??? #29
+1
A major reason I own Deere instead of Kioti is having several great Deere dealers nearby and having only a few Kioti dealers in the entire state, none of them close to me.
If the dealer is good, I would have no hesitation on Kioti. For any brand (including Deere), if the dealer is bad, I would look elsewhere for a brand with a good dealer.
IMHO, your tasks won't benefit from filled tires on something as big as a DK45, so if you go that route I would leave the tires with just air, get some weight on the 3ph for FEL ballast, and save yourself 1000lbs or more that would otherwise be compacting soil. (My view would be different if you planned heavy loader work or heavy tillage.)
/ First Tractor. Deere 3720??? #30
Not quite sure what that means, but I have a 2001 Kioti DK 35 with just under 1000 hours. Works great, no problems.
I have been pleased with the dealer, pleased with the machine.
/ First Tractor. Deere 3720??? #32
metroski said:
check this link, I came across this while gathering research information.
could be outdated or just a nonsense view.
The Small Tractor FAQ - Frequently Asked Questions
I think it's both outdated and just one person's view. Both Kioti and Zetor are considered excellent tractors, while many of the other "challenged" listings are not. They also completely omit Mahindra and TYM.
I would do a lot of reading on this boards, especially in the owning/operating forums for each brand you're considering, and see what problems owners actually seem to be having. The only Kioti issue that comes up a lot is loader frame cracking on some of the CK series, but it is being fixed by Kioti.
/ First Tractor. Deere 3720??? #33
I have seen this posted once before a while back.
Very outdated.
If you click on Kioti on the webpage posted it takes you to the Lely Corp. homepage.
Lely has not been the distributor of Kioti tractor since prior to 1993.
Daedong (the Mfg. of Kioti tractors) has been the distributor of their own tractors for the past 14 years.
Just as a reference. How does an ATV with a pull behind attachments measure up to a tractor for tasks such as field mowing, disc-ing, spraying, seeding etc.
I have a 700CC quad and was wondering if spending a few thousand on quad "implements" would be comparable to the tractor. I wouldn't have the loader or the post hole auger but could save about $25k. Also no cab.
Just figured I should ask. You guys have been so helpful on everything else.
More than likely I'm gonna go for the Kioti 45 cab but was curious.
Mike
/ First Tractor. Deere 3720??? #35
The ATV will be smaller and more limited in all tasks. I think it would do ok on spraying, seeding, and mowing, if you buy the special ATV implements for each. I don't think it has enough power to pull a disk that will do very much good.
If this were an appealing option, you could always use the ATV for fieldwork and get a used skidloader for the loader and post-hole work. Skidsteer is definitely a great tool for both, but it's not a good tool (or even capable of some tasks) for fieldwork.
/ First Tractor. Deere 3720??? #36
I doubt you would be happy mowing with a four wheeler. Spraying and spreading arent bad but all the turning and backing up with a trailer can get old.
/ First Tractor. Deere 3720??? #37
I agree. I think spraying with a 4 wheeler is a real pain when using a hand wand but maybe a boom sprayer in the back wouldn't be to bad.
/ First Tractor. Deere 3720??? #38
metroski said:
The pastures are massively overgrown and need a lot of work.
I was using the brush cutter (down here we call it shredding) yesterday in 3-4 foot tall weeds and grass. I had to park my 25 hp PTO 4310 and get out the 65 HP 5420. It still had trouble in the thickest parts with just a 6 foot cutter. I know it wasn't the lack of HP cuz the slipper clutch on the bushhog cutter is rated for 85 HP and it would slip a little when bogged down in the deep stuff. What I'm trying to say is, if your pastures are really overgrown, the amount of HP will determine how much you can nibble at the task. You can take less than full width cuts if your tractor is not up to the task. My 4310 was slowing down to a crawl with only half a cut. The grass is bahia which is like cutting wire rope when its dry.
I'm not sure of the DK's horsepower, but I'd sure like to have a 3720 myself for the available HP in that size of machine. I'd recommend you test drive both at least twice and shop price between dealers while comparing dealers. Parts, service and attitudes are what to look for while comparing.
Good luck...Kyle
/ First Tractor. Deere 3720??? #39
I'd just like to have the above post read again as it is VERY true.
My old-timer neighbors have seen me out in the field then stopped to talk about my little tractor and offered to help, loan implements and/or given advice. Maybe it's a Deere thing? ;)
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Traxmax 300 Stand-On Sod Installer (A59228)
Traxmax 300...
2019 KOMATSU PC210LC-11 EXCAVATOR (A60429)
2019 KOMATSU...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
