First time owner of JD tractor (used)
   / First time owner of JD tractor (used) #1
Brandy Robinson
Wann, Okla
JD compact 790 yr 2006
Tractor was running great, no problems until last week. won't start- new battery, terminals, and fuses all replaced. No battery indicator light showing. Has head lights and oil light lights up when you turn the key, but nothing else. Whats my next step?
:confused2:
   / First time owner of JD tractor (used) #2
Check your safety switches. PTO and stufff
   / First time owner of JD tractor (used) #3
Hi Brandy,
I'm no expert in the things too technical, but bet I've done all the easy mistakes! Has the gear shift been pushed out of neutral? Is your PTO switch in the on position? Any other safety add-ons in a false positive state?
Good Luck.
Frank
Have checked all of those things, still will not turn over. Battery indicator light does not show battery, however tested new battery and it has full charge.
   / First time owner of JD tractor (used) #5
Well check all bat and ignition wires and connections.Don't look at them take them off and clean them.
   / First time owner of JD tractor (used) #6
Not familiar with JD but you might look for a (blown) fusible link...possibly near the alternator...
Well, I thought I had it. Back to square one- did a quick crank and now nothing- no lights either. :(
   / First time owner of JD tractor (used) #8
I am betting on a safety switch somewhere, even if you think you checked them all (there can be as many as 5-6 on modern tractors). It is by far the most common cause of "can't start my new to me used tractor" posts on TBN.
   / First time owner of JD tractor (used) #9
Either that or dirty Batt connection
   / First time owner of JD tractor (used) #10
All viable suggestions...might double check the main ground on the tractor frame...also a cold sticky relay on the original symptoms...
Good Luck...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2025 AGT QK16R Mini-Excavator with Dozer Blade & Hydraulic Thumb (New/Unused) (A59225)
2025 AGT QK16R...
KING KUTTER 5' DISC BLADE W/ 1PT HITCH (A52708)
KING KUTTER 5'...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
