First time owner of JD tractor (used)
   / First time owner of JD tractor (used) #11
Welcome to the forum.
:welcome:
I'm going to move your thread on over to the John Deere section in case you need more advice. I hope you get that tractor running again soon!
   / First time owner of JD tractor (used) #12
:welcome:
What happened to Brianna?
Murph, you were correct. There was a loose wire from the positive side that connected to the (I am going to say "safety switch") located near the diesel fill. Does that sound right? Anyways, everything seems to be coming to life again. Thanks for your help. Sometimes, it just takes someone saying- recheck. Appreciate it.
Brandy
   / First time owner of JD tractor (used) #15
All viable suggestions...might double check the main ground on the tractor frame...also a cold sticky relay on the original symptoms...
Good Luck...
+1, if the lights won't turn on the ground is a very likely candidate.
Do you have a vom and know how to use it?
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
