First service with only 14 hrs ????
   / First service with only 14 hrs ???? #1
cvcman
syracuse ny
john deere
I bought my new Ls2025 in August....only have 14 hrs....got a card from dealer saying be sure to do the service....is there break in lubes in the oil etc that I really should leave in until 50 hrs ???
Thx
   / First service with only 14 hrs ???? #2
Thx
The notice is based on average hours by customers. The 50 hr service is to clean out dirt and some machining filings left over from manufacturing and assembly.
If you do it yourself be sure and clean the suction screen on the hydraulic tank as well as the filter.
I understand why the 50 hr is done...guessed you missed my point/question....I ONLY have 14 hours....I would think I really should wait till 50 hours to do the service due to break in lubes added when new etc....even though many people have 50 hrs in a yr ,I do not
thx
   / First service with only 14 hrs ???? #4
Dude, relax.
   / First service with only 14 hrs ???? #5
thx
Yes you should wait till 50 hrs. The dealer sends the notice based on other owners average usage and when they reach 50 hrs. The dealer is trying to get more business.
   / First service with only 14 hrs ???? #6
I am unsure what engine oil type your tractor is shipped with. In the case of my Kubota nothing in the manual refers to "break in" oil being used. So I'd say the first change should be based on hours and/or time.
I'd certainly change the oil if a year goes by, regardless of how many hours you have on the meter.
I run a John Deere road grader. The new machine was shipped with break in oil. The manual specifically talks about that. Says to run the machine to the recommended hour before changing. Also states if additional oil is needed to only add break in oil. So that's how we serviced it.
   / First service with only 14 hrs ???? #7
I have heard about break in oil for years and still don't know what it is. Also have never seen it for sell any place. I think the next time I go to the auto parts store I'm going to ask. I have done major overhauls many times and always used what was to be ran in the engine.
   / First service with only 14 hrs ???? #8
I agree. With that said, I am not about to give the manufacturer a reason to not warrant and engine failure. I diligently added break in oil when needed. I didn't change it out until I had reached the recommended hours on the meter.
I think you would have to go to a manufacturer's parts department to buy break in oil. I had to go to JD dealer.
   / First service with only 14 hrs ???? #9
Do what you feel most comfortable with its your machine. if you want to change your oil filter and not the oil to remove contaminants from break in or machining it doesn't hurt and it's cheap insurance. I changed my filter at 23/24 hours but I changed my oil at 50 along with a new filter
LukeStaford.....Dude,,,I AM relaxed,lol
Yea I called the tech guy at LS after buying and he is the one that told me they put break in lubes in the oil when it is assembled..the cost of the oil and filter is nil...just thought with only 14 hrs on it was a waste...shoot I may not have 50 on it next year either
   / First service with only 14 hrs ???? #11
LukeStaford.....Dude,,,I AM relaxed,lol Yea I called the tech guy at LS after buying and he is the one that told me they put break in lubes in the oil when it is assembled..the cost of the oil and filter is nil...just thought with only 14 hrs on it was a waste...shoot I may not have 50 on it next year either
It would be a waste just change it 50 hours or 1 year rolls around. My Honda Accord came with break in oil the manual said not to change it early.
The dealer card was just a reminder to use him.
   / First service with only 14 hrs ???? #12
Thx
Wait till you get closer to 50 hrs before changing. You're probably going to use it for plowing snow so you'll add some hours this winter. If you don't have 50 hours by next August then change it. When you do use a diesel rated oil 0W-30, 0W-40, or 10W-30 which will make it easier starting in cold weather. I've only got 88 hours on mine in 22 months. I did mine around 50 hours. I did not have it tested but it came out clean, no visible metal or contaminants. I did use synthetic oil when I changed it but that's not a necessity.
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
