First Plow- Do I leave the shoes on??
   / First Plow- Do I leave the shoes on?? #1
bebop86
NJ
May be a dumb question- Just got a Boss Plow for my Kubota 5940- Do you guys leave the shoes on the plow or should I take them off for a paved driveway- thks
   / First Plow- Do I leave the shoes on?? #2
On is good! Are they adjustable?
   / First Plow- Do I leave the shoes on?? #3
Honest question not dumb question. :)
   / First Plow- Do I leave the shoes on?? #4
The shoes should have several washers for height adjustment. I'd leave them on as long as they are adjusted right.
   / First Plow- Do I leave the shoes on?? #5
If the ground is frozen. No shoes on plow truck or tractor.
If the ground is soft, I really try not to plow. 6", I think about it.
   / First Plow- Do I leave the shoes on?? #6
my driveway pavement is in good shape, flat with no cracks or areas for the plow to catch.
I keep my shoes adjusted up so the plow is clearing all of the snow. the only issue is, it is hard on my sealer or coating.
   / First Plow- Do I leave the shoes on?? #7
For hard surfaces, I leave the shoes adjusted even with the cutting edge to provide the closest "shave" while providing many additional square inches of wear surface. Then leave it alone and it all wears down together.
   / First Plow- Do I leave the shoes on?? #8
I never use the shoes. They are more expensive than cutting edges. In spring storms the shoes dig into gravel surfaces and make ruts.
   / First Plow- Do I leave the shoes on?? #9
Generally shoes or skids are used only for first snows until a base is created and that mostly on gravel drives.
Even so shoes always dig a bit on gravel and many guys simply back drag the plow to compact first snow falls.
The worst possible event is a heavy dumping (10-12") on a non frozen base especially if that snow is wet.
Nothing works well in those conditions!
   / First Plow- Do I leave the shoes on?? #10
We just about always get snow on a non frozen or barely frozen base.
378811 (A51573)
378811 (A51573)
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
Skid steer auger plate (A50322)
Skid steer auger...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
