May be a dumb question- Just got a Boss Plow for my Kubota 5940- Do you guys leave the shoes on the plow or should I take them off for a paved driveway- thks
my driveway pavement is in good shape, flat with no cracks or areas for the plow to catch.
I keep my shoes adjusted up so the plow is clearing all of the snow. the only issue is, it is hard on my sealer or coating.
For hard surfaces, I leave the shoes adjusted even with the cutting edge to provide the closest "shave" while providing many additional square inches of wear surface. Then leave it alone and it all wears down together.
Generally shoes or skids are used only for first snows until a base is created and that mostly on gravel drives.
Even so shoes always dig a bit on gravel and many guys simply back drag the plow to compact first snow falls.
The worst possible event is a heavy dumping (10-12") on a non frozen base especially if that snow is wet.
Nothing works well in those conditions!
