First Oops with Bobcat 331 - hydraulic leak
   / First Oops with Bobcat 331 - hydraulic leak #1
EdDekker
New Ipswich, New Hampshire
Kubota B2400, Bobcat 331 Mini-Excavator
I had my new-to-me Bobcat excavator (link) out this afternoon to move the pieces of a tree which came down this winter.
I have the branches chipped and most of the pine needles moved away so it was time to move the hunks of tree trunk.
Slinging the tree pieces below the bucket worked well. I looked like I knew what I was doing as I moved the pieces. I moved two chunks of tree and while moving back to get the third I saw a problem.
I noticed I was leaving an oil trail wherever I drove. I got out and looked at the under carriage and hydraulic fluid was pumping out near the traction motor. After shutting down the engine, the oil continued to come out for a long time. I looked closer at the oil and could not determine exactly where the leak was. The oil was flowing down the inner side of the right traction motor
I traced the oil trail back and it starts in the driveway right where I pressed the high speed pedal, and it lost oil continuously after that.
Any suggestions on what I may have broken from the bobcat excavator experts out there?
(photo 1 of tree pieces to be moved attached)
(photo 2 of tree pieces to be moved attached)
(photo - chain on ground and log about to be rolled onto chain)
photo - Lifted and moving but oil trail in background
Photo of oil trail in the driveway. Start of leak was well before I got close to the tree, starting at the edge of the damp area. This was the spot I pressed the high speed pedel.
   / First Oops with Bobcat 331 - hydraulic leak #7
Ed, I'm curious to know why you aren't using your thumb? /forums/images/graemlins/confused.gif That's what that's for....anway. Just what I'd do. That's too bad about the leak. I can't tell you anything because I've had zero experience with mini trackhoes. That's a nice one you have though.
Blake
WA
The leak
close up of the leak.
   / First Oops with Bobcat 331 - hydraulic leak #10
Ed,
I can't help you with the leak. I know absolutly nothing about such machines. Being in New Hampshire, the best advice or suggestion I could give you is to call BobCat of NH in Chichester @ 603-224-1234
Good luck /forums/images/graemlins/smile.gif
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
