First Oil Change X590 -- Oil Filter Wrench?
   / First Oil Change X590 -- Oil Filter Wrench? #1
tguil
JD 1070
Getting ready for the first oil change (8 hours) on my 2016 X590. A small strap filter wrench will not work. Not enough room to get any leverage. If it is like any other factory oil filter that I have attempted to remove, the filter is going to be on darn tight. (That's why I always have the dealer do the first oil change on my trucks. If they mess up, it's the problem not mine.) Any suggestions for a problem free removal of this filter? Any wrenches made just for this tractor?
   / First Oil Change X590 -- Oil Filter Wrench? #2
It is easy to just buy the wrench that fits the filter .
I have three for different size filters they are cheap .
   / First Oil Change X590 -- Oil Filter Wrench? #4
I use a large channel lock wrench to remove.. hand tighten tho.
   / First Oil Change X590 -- Oil Filter Wrench? #5
I just did the first oil change on my x590. I picked up the oil filter wrench from my John Deere dealer before performing the oil change as I had read many stories of difficulties removing the filter. The oil change went smoothly with the wrench.
OK, thanks for the suggestions. I have the the Deere wrench. Is it necessary remove the side panel to get at the filter and remove it completely. It's a tight fit. If you remove the panel, how? It appears that there is only one screw attaching the panel to the frame.
   / First Oil Change X590 -- Oil Filter Wrench? #8
you dont have to take panel off, but easier if you do, it comes off with the 1 screw ( if I remember correctly ) take 2 min or less
Thanks, that's what I thought.
   / First Oil Change X590 -- Oil Filter Wrench? #10
I'm a big fan of this type of filter wrench. It's geared inside so as you turn counter clockwise the teeth bite in. One size fits all. :)
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
