First mod to my 2210
/ First mod to my 2210 #1
megotatractor
New Richland, Minnesota
JD 2210
Earlier this winter I realized that I couldnt' see backing up in the dark plowing snow. So a trip to the Fleetfarm store to get a utility light. simply plugged er into the connection in the back and fished a wire up the ROPS. used the existing signal light mounting bolt. see pic. Once the light was installed it stopped snowing so I dont know how it works yet. /forums/images/graemlins/mad.gif
/ First mod to my 2210 #2
looks great! I have a dealer installed Work light on my 5103 and it really helps! /forums/images/graemlins/grin.gif
/ First mod to my 2210 #3
mego,
Very nice. My next comment would be, how do you still have lights hanging on when positioned on the outside of the ROPS's? Mine are inside . . . for good reason! /forums/images/graemlins/tongue.gif
/ First mod to my 2210 #4
</font><font color="blue" class="small">( simply plugged er into the connection in the back and fished a wire up the ROPS. )</font>
<font color="green">Megotractor, Did the connector that came with the light fit the connection in the back of the tractor or did you have to use some sort of creative means to make the connection?
Mike </font>
I used a standard male spade connector with a length of shrink tubing to cover and seal it.
JD, is there a problem with the outboard signal lights? I had a few low branches grab at them lights when I first got the tractor but that was solved with a pruning saw and a little driving experience. /forums/images/graemlins/grin.gif
/ First mod to my 2210 #7
I kept having to tighten the bolts holding my lights in place and finally had to replace one of them, at $56. The parts lady suggested moving them inside. You have to swap sides with them. Did so. No loose or broken lights since.
Ralph
/ First mod to my 2210 #8
mego,
I did what Ralph described for the same reason. As I understand it, Deere sets them on the outside to comply with the SMV standard which has a spacing requirement. They do look close together inside, but they're a lot safer! BTW, I understand Deere now offers a protective cage for the lights. /forums/images/graemlins/tongue.gif
/ First mod to my 2210 #9
</font><font color="blue" class="small">( You have to swap sides with them. )</font>
<font color="green">Ralph, why did you have to swap sides with the lights?
Mike </font>
/ First mod to my 2210 #10
Think I swapped sides to keep them oriented the same. Don't remember the details now.
Ralph
/ First mod to my 2210 #11
The lenses have different colors (red, yellow, and white) to keep the orrientation the same, you need to reverse the mountings. /forums/images/graemlins/tongue.gif
/ First mod to my 2210 #12
<font color="green">I moved my lights on my 2210 to the inside but didn't have to swap them. The red lens just ends up on the bottom but still on the left side of the tractor.
You really don't want the red lens to end up on the right side if you drive the tractor on the road at night. Unless of course you are driving on a road in England or Australia. /forums/images/graemlins/grin.gif
Mike</font>
/ First mod to my 2210 #14
Looks Good. crazylare1 has somthing similer to that on the 3320 here at the house. There are two of them facing the front and one in the rear. We have found out that they don't shine very far.
Cam
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
